Windows 10/11 Download
search for Bitlocker.
We had an issue last week where a few of our office machines booted up and were asking for the Bitlocker Key. We had the keys for 3 of them but the other 2 we did not. Luckily we rebooted them, and they booted fine without asking for the code again. We then made a backup all all bitlocker codes for all machines in the building after that.
Device encryption is not available to me in Settings. Maybe since I don't sign into my machine using a Microsoft account, it doesn't make it available.
I ran the command prompt as arlo suggested and it says my drives are not encrypted, are unlocked, and that Bitlocker is not installed.
Thanks.
Reactions: primestar31
I just recently upgraded to Win11. How do you turn off disk encryption? I did a search and the instructions said to use the window key and type "manage encryption", but all that does is a search for how to. When I click on the how to, it just says to do the search. I haven't found any app or procedure for how to turn off disk encryption or Bitlocker.
When I go to Settings, Privacy and Security, there is no such option to disable disk encryption.
Thanks.
Reactions: harshness
I don't have a "System and Security" option under control panel. I do have a "Security and Maintenance" tab, but nothing under it relating to Bitlocker.
I have a "System" tab also, which takes me to System About. Under that is a "Bitlocker" tab. When I click on that, it takes me to the Microsoft Store to buy Windows Pro for $99.
So, maybe Bitlocker and Device Encryption are only available in Pro. I'm running Home.
Thanks.
Thanks.
Google shows this:
Windows 11 Home does not have the full BitLocker Drive Encryption feature, which is only available on Windows 11 Pro, Enterprise, and Education editions. However, Windows 11 Home may automatically enable a basic feature called Device Encryption, which uses a BitLocker recovery key to protect your data and saves the key to your Microsoft account.
Windows 11 Home and Device Encryption
Basic Encryption:
Windows 11 Home includes a basic Device Encryption feature that can automatically turn on if you sign in with a Microsoft account and your device meets certain hardware requirements.
BitLocker Recovery Key:
This basic encryption uses a BitLocker recovery key to secure your data.
Key Storage:
The recovery key is automatically saved to your Microsoft account, so you can access it there if you need it. You can also find it by going to Settings > Privacy & security > Device encryption and looking for a backup option.
Not Full BitLocker:
This is not the same as the full BitLocker Drive Encryption found in Windows Pro, which offers more options like encrypting external drives.
Try opening Settings and do a search for Bitlocker
I have Win11 on 2 laptops and they're not using disk encryption. I upgraded Win10 on 2 PCs and neither installed disk encryption. I don't have secure boot setup on any of them so maybe that's the difference?
New Windows Feature - how to Turn it Off?
