I would expect it to be.The pedestal has a lock on it so I can't check that.
I've asked my builder for help on this. My place is new construction and the builder is very good about advocating for new home owners. My area is not that large so I am hopeful the builder's electrician will be able to extract some info from someone they know personally at Spectrum. I will be sure to post any info I get from the builder. Thanks all for the discussion, it makes me determined not to just let this slide by.I would expect it to be.
That's because they don't want former customers reconnecting themselves thinking they can get something for nothing.The pedestal has a lock on it so I can't check that.
The cover regularly falls off the pedestal across the road from me. It's located in some brush, and when the wind blows, off comes the cover. I've never seen a lock on it.That's because they don't want former customers reconnecting themselves thinking they can get something for nothing.
The coax line going into the Pedestal will be connected to a much larger connecting block (for lack of the correct term at the moment)I would expect it to be.
If your all that concerned, call Spectrum back out and have them reconnect the ground wire ... or do it yourself.I've asked my builder for help on this. My place is new construction and the builder is very good about advocating for new home owners. My area is not that large so I am hopeful the builder's electrician will be able to extract some info from someone they know personally at Spectrum. I will be sure to post any info I get from the builder. Thanks all for the discussion, it makes me determined not to just let this slide by.
Yes thats where they unscrewed it from. But go out of your way to cut the ground? and not unscrew from the home also?....Your standing there....lolThe coax line going into the Pedestal will be connected to a much larger connecting block (for lack of the correct term at the moment)
That connecting block is Definingly already grounded ....
That Coax IS grounded, provided it's terminated correctly.
They are typically at the base if it has one and often times, they don't want to get down to the lock or put the cover on correctly, could be in a hurry or maybe theres other items keeping the cover from closing all the way.The cover regularly falls off the pedestal across the road from me. It's located in some brush, and when the wind blows, off comes the cover. I've never seen a lock on it.
The Coax is feeding his signal, if he still has service, if not, I don't understand what the issue is, if he's not using the service, take it down if he wants .. and remove the ground.I'd just disconnect the coax in the box and remove the grounding cable. Those clips pull right out of the siding.
I'm thinking it was probably already cut ... just my thinking and they wouldn't know it unless a service call as generated.Yes thats where they unscrewed it from. But go out of your way to cut the ground? and not unscrew from the home also?....Your standing there....lol
This is typically not the case if you've cancelled service, as is the case here.That Coax IS grounded, provided it's terminated correctly.
That was 30+ posts ago.This is typically not the case if you've cancelled service, as is the case here.
You should read at least the first sentence of the OP to set the stage.
Practically (unless your area is subject to ground strikes), it probably doesn't make any difference.They tell me as long as I'm not using any Spectrum services the cut ground doesn't matter.
NEC 820.93 said:(A) Entering Buildings. In installations where the coaxial cable enters the building, the outer conductive shield shall be grounded in accordance with 820.100. The grounding shall be as close as possible to the point of entrance.
