I hit the wrong button on the remote in the menu and changed the NTSC mode. If anyone knows of way to reset this receiver please let me know. Thanks.
Does it have a Webif, like the Edision Mio's so you can bring up the screen in a browser, and navigate the menu to fix it?I hit the wrong button on the remote in the menu and changed the NTSC mode. If anyone knows of way to reset this receiver please let me know. Thanks.
What image is it running? Should have a Webif.Not that I know of. This has happened before and I have received instructions from other sources on how to correct it with no problems. But for some reason it's not working this time. I only use the 8008 for storing sports feeds so I guess I will have to go back to using the Linkbox 9000 for that.
If you are using the linuxos Define software try this.I hit the wrong button on the remote in the menu and changed the NTSC mode. If anyone knows of way to reset this receiver please let me know. Thanks.
Seems to me if you can see the octagon logo screen and a channel number on the display then it doesn't sound like the software is working properly. You will have to get in the recovery mode and boot into another multiboot slot or download and reinstall.If you are using the linuxos Define software try this.
Turn on and press exit on the remote a few times to make sure you are out the menu screens.
Press menu on the remote once.
Press Fav on the remote once.
Press down arrow on remote once.
Press ok button twice.
Use the up or down buttons after each press of the up or down press ok .
That cycles the resolutions. Maybe you will get lucky and get a picture on a mode.
If not to get
to recovery mode Press exit a few times then press menu, press Fav, press ok.
press down arrow four times then press ok. should reboot into recovery where you could reinstall the OS.
I tried the above section, the Octagon logo screen came on and the the front showed the channel numbers, that was all.
Or there is a tiny button on the back for recovery mode. power off and hold recovery button
and power back on while continuing to hold the recovery button until you see UPGR on the front panel then release the recovery button and it will boot up in recovery mode.
I tried this 4 times holding the recovery button for approximately 30 to 45 seconds. Nothing came up on the front panel nor did it reboot.
Thanks for your effort, ai appreciate it.
I just timed it on the Octagon sf8008 I have here and with the power switch OFF and pressing the recovery in I Flipped on the power switch and less than five seconds the front display showed UPdt and I release the recover button then the box booted into recovery screen on the TV in less than 30 seconds.I just can't get the menu to show up. If I could do that I know what to do to reset it. All I was going to do was adjust the brightness a bit. When the menu came up I started to scroll down to do that and everything just went dark. So I just don't know what to do to get the menu to show back up.
"You got to flip the power switch off then hold the recovery button while flipping the power switch back on and wait for the display to show UPDT then release the recover button and wait for the recovery screen on the TV."
SDA_FL_USA : I have tried that a few times and nothing happens on the receiver or the TV. Do you know how long it should that for it to show up on the TV?
Try this I found it on the web and much easier.Thanks for that information. I will try again, but the few times I try UPdt never shows up on the TV or the receiver. It boots up the receiver and the channel numbers come up on it.
