two success stories
The hard way:
One of my friends is a retired engineer from a major L.A. TV station.
I just got off the phone with him, to verify these facts...
He moved out into the boonies where there are only a couple of VHF stations around: 3, 6, & 12.
From the TV antenna, he runs through three band pass filters, one for each channel.
Next, he's got a pre amp, and then runs that via RG 6 into the house.
Somewhere along the way, he picked up some surplus commercial modulators.
They're made by Blonder Tongue, and would have been around $350 each, new.
He's set them on channels 7, 8 , 9, & 10.
Because they're commercial quality, they can actually be placed on adjacent channels, unlike consumer units!
The modulators feed some sort of rack-mount commercial combiner, which he says is a pretty simple box.
The combiner's output is fed through the house, where any TV can select the three local stations, or the output of his four satellite receivers.
Yes, he actually leaves three of them on fixed channels for easy access.
The easy way:
Another buddy wanted to combine his cable TV with the output of several satellite receivers.
Obviously, most of the channel frequencies were already in use.
We experimented with some frequency agile modulators like the ones Sadoun sells.
These came from a close-out deal at Radio Shack last year, and look almost identical.
The features are certainly the same.
His cable went up through about channel 79, as I recall.
He tried using a standard high frequency TV splitter backwards to combine the two signals, but had interference between cable and his modulator.
In the end, he got a $30 filter from Minicircuits (I think it was a low-pass) at channel 80
The output of the filter cut the cable-carried garbage above channel 80.
Then, he used a 4-way TV splitter -backwards-, and combined the filtered cable with 3 modulators set to channels 82, 84, and 86.
That seemed to work fine, with no more cross interference.
Now he feeds his three video sources throughout the house, along with regular cable TV.
I described this approach to my TV engineer, and he was impressed.
He didn't knock the design at all. :up
-[30]-
The hard way:
The easy way:
-[30]-
