Yeah I really don't want to spend the $50 on the dish, but on the other hand, it's solid and not mesh, and there aren't many dishes around this area anymore. I've even put ads in the paper for one, with no bites. The ones I do see are mesh, and I'd like a solid dish, so I can get decent KU and C band reception. I asked if she wanted to give it away, but she said she had a friend interested in using it for a swimming pool (how she expects to do that, I have no idea), and said if she can make a little cash on it, she'd reconsider giving it to her friend. So I offered $20, she said no, offered $40, and she said make it $50 and you can have it. I told her I'm interested, and to not get rid of it. Haven't talked to her since. Just went back to take the pictures. I don't want to spend the money, yet at the same time, I'll probably regret it if I don't get this dish. I figure, at the end I'll have around $450 into the setup.
That includes the Ku/C LNB, the Vbox II positioner, 350 feet of ribbon cable, and a mercury II receiver. Worth the investment?
I'm not gonna buy anything until I get it setup in my yard and I can test everything out with the current receiver and see if everything works and I can get a decent line of sight to the satellites.
How much do you think that bent section will affect the signal? I think I might be able to pound it back into a mostly normal shape. I do believe that it was in use after the dent was put there. Her husband used the dish up until his death, and he also put the dent in there, so I assume the dent was there when it was still in use. This is the first and only solid dish I've found in this area. $50 isn't much, I guess I can take the risk. I'm always on the lookout for dishes now, so maybe I'll come across another one. Hell, I'll just collect them and keep them in the garage, or put them in an array, each pointed at different satellites, boy my neighbors would just love that.
That is correct. I would put one string on top of the dent, and the other at 90 degrees from that. That will tell you how bad the warp is. Then I would try the strings at another point that doesn't involve the dented part. That will tell you if it is an isolated warp or not.
Myself, I wouldn't pay $50.00 for it, but that is just my opinion. Others might have a different idea. Dishes might not be as plentiful as they are in my neck of the woods.
If you can get it free, and can take out the warped section, or beat it into place, then it might be worth the trouble.
Again, it's just my opinion! Take it for what it is worth.
Fred
