I have not noticed any difference. What's up with this pole?
Which pole?![]()
All the channels look good to me, except TBS and NBA, which I cannot watch because they're on transponder 6, which jumps between 0 and 6 for signal strength.
Aaron - you can fix that in three different ways (I'm assuming you have a "Dish-1000"):
- Add an 18-inch dish pointed at 61.5, which has the same channels from a stronger satellite.
- Assuming that you have a Dish-1000, have it replaced with a Dish-1000.2 which is the same, except that it works better with 129.
- Add a 24-inch dish pointed at 129, which will have stronger reception on 129.
If you call Dish and speak to Tech Support, they should be able to correct your problem without charge to you (be sure to verify that while talking to them).
Yep. I already have the 1000.2, and I already have a 2nd 18" dish to pick up 61.5. I'd drop 129 altogether, but my locals are on it. Sometimes the receiver chooses to grab TBSHD off of 61.5 (signal strength 50-70), and I'll be able to watch it with no problems, but most of the time the receiver likes to try to get it from 129 and then fail without reverting back to 61.5. Oh well.
A 24 inch dish is a possibility, but it's only that transponder that is awful, and I rarely watch any of the channels on it.
