This Diagnostics screen layout is different. Seems to be the only user-facing thing that I have noticed.
My Hopper 3 Plus & my other Hopper 3 are both on H706. Both Hoppers & Joey 4s have the same whitish background like in the pic post #1.H+ = difference?
I checked on this error. It means (for me anyway) that 77 is no longer in use although at one time it was on my receiver. The previous versions ignored the error because it was no longer in use. The current version shows it . ????I upgraded my two Hopper 3 receivers to H706 and my two Joey 3 clients to J906.
The diagnostics screen on the Joey 3 has much more information.
When I do a Check Status on my two Hopper 3 receivers I have an Error: Port 3 Generic Warning
Everything seems to be working fine so I am not sure what the error means. All of my external hard drives and the OTA tuner are all working. Does anyone know what that error entails?
A satellite location. Dish stopped its use in 2011.What is 77?
It might disappear if you do a check switch.That makes sense. Satellite 129 is still connected to my DPH 42 switch but it is no longer used. Thank you for the explanation.
Maybe it's the way I have my picture adjusted on my tv. I still have a dark backgroundMy Hopper 3 Plus & my other Hopper 3 are both on H706. Both Hoppers & Joey 4s have the same whitish background like in the pic post #1.
Been while since I did check switch the same error even on 708 for the hopper 3 so guess this bug and they never bother to fix it? DP switch port 3 and 4 are not even used they are capped stillI upgraded my two Hopper 3 receivers to H706 and my two Joey 3 clients to J906.
