After searching and reading and searching some more - I'll pose my question a I need help.
I bought a 721 and changed to a DPP Twin feed, I'm running two other receivers on the same set up, the 721 is the third, by the way the other receivers are working fine. I'm using the seperator and just cant get passed the check switch, also the receiver itself is doing some strange things like getting caught in reboot loop as well as freezing.
I updated the sw right out of the box and now it often sticks on "Acquiring Data From Satellite" for a while and the I can access the menu. I have a good signal when going into Dish Pointing Screen. I do a check switch and it goes thru 1 of 28 on tuners 1 and 2. Tuner 1 always finishes up way before tuner 2. I might get nothing on the check switch results or it might just detect the 119 on tuner 1.
It's just acting wacky.
HELP!
John
HELP!
John
