Automatic HDMI switcher does not auto switch back to HR44 Genie, does yours?
$905.00
Rockstead
170
5
Earth
I purchased an upgrade to the very popular Kinivo HDMI automatic switcher. I bought the new 4k 5 port model K500.
I placed the Genie on port 1 and it works, let's say I turn on my PS4 on port 2, it automatically switches to port 2 and PS4 shows.
Here is the issue, when I turn off PS4, it doesn't fall back to port 1 for Directv, but it works when I manually switch back to port 1.
I just want to confirm if this is an issue with my switcher or will all switchers have this problem with the HR44?
I suspect this is because the switch is autoswitching based on the 5v pin in the HDMI interface. Unfortunately the 5v is not a mandatory requirement on HDMI, so devices not supplying 5v won't be detected, and I am pretty sure the HR44 does not supply 5v. I remember seeing another post where a device was actually being powered by the 5v pin and so would not work at all with the HR44.
EDIT: Actually I remember now, it was an HDMI to fiber interface, and would iot work without an external power source because the Hr44 did not supply 5v.
I am powering the switch with an external power supply that came with it, based on what you said, should it be working with that power supply in play?
No, I used the example only to illustrate the Hr44 does not supply 5v on the HDMI interface. I am pretty sure your switch is using the presence of the 5v as its autodetect, to see whether a particular port has a device attached. Since the Hr44 does not supply 5v, the switch autodetect circuitry does not know the HR44 is there.
Change the priority of your devices by trying them on different switch ports, and see what happens.
What's wrong with this picture?
AHC in HD
