AZBOX Premium HD IPTV (IP Channel)
vpaniyan
55
US
Guys,
I set up AZBOX for IPTV (IP Channel), but all URLs I tied are down.
Can you please reply with couple of URLs that are active.
JAS
386
In the USA
My internet connection is to slow to try.
Iowa Public Television/IPTV
I don't have the address but should not be hard to find.
Found it www.iptv.org/
Forget it I'm confusing Iowa Public Television (IPTV) with IPTV (IP Channel)
Jim S.
When someone asks you if you're a god, you say yes
5,868
1,678
FN11od
Are these really IPTV channels listed? Most of those simply appear to be bootleg video feeds....
But that's (internet streaming) what the AZbox is calling an IPTV channel, right? There's no consumer receiver that does IPTV direct from satellite, right?
AcWxRadar
4,575
4
40 miles NW of Omaha. Omaha?
Correct. You can create IPTV channels to stream from the internet to your AZBox using HTTP or to stream TO/FROM your AZBox to your WLAN using UDP.
I have been able to stream back and forth inside my WLAN (using VLC Media Player). However, I haven't yet been able to find any direct IPTV channel that
works with the AZBox over the internet (unless you consider YouTube).
Well, NO not through the tuner itself from a satellite.
But, if you consider that my internet connection is a satellite connection, then in a round-a-bout way, yes. That doesn't really count as the same.
RADAR
vpaniyan
55
US
I learned that AZBOX has 4 channels and I tested it - works: TV Channel, IP channel, Protocol - HTTP, TV Type - kartina.tv.
Regarding "should not be hard to find" - yes, it easy to find, but these sites require navigation and AZBOX does not provide this function.
photoman76
3,291
There are some IPTV satellite streams that can be viewed using a Prof 7500, TSReader and VLC media player. However, most satellite IPTV is encrypted or is encapsulated in some weird format that is difficult to play back.
georgekamal
Mar 2, 2010
18
universe
will this receiver work for IPTV stream from the satellite?
xxx.satcomresources.com/Novra-S75-DVB-Receiver
AZBox Premium +; help w/ scan ?
AZBox P +; time set glitch; timer question
