Bud
WyrTwister
769
Dammaged dish
Just scrounged an old mesh dish . Lot of damage .
At least one rib broke and a section missing . Looks like 2/3 to 3/4 of the dish is intact ?
How much damage can a dish tolerate & still give a better signal than mt 90 cm mini bud ?
I have seen a dish shaped like a map of a state . Know that is not a perfect shape .
Realize I need to at least repair it to the extent of trying to remove as much warp as possable .
Will try to take & post some pictures tomorrow .
The mount appears to be for a square pole ? The big set screws might tighten down on a round pole ?
Had to take the dish apart to haul it .
Very slim chance the dish mover might work . Scalar ring / feed horn non adjustable Chaparrel . Doubt the polaroter works ? That goes doubble for the LNB .
Got too dark too fast to tell much more about it .
Wyr
Nice find, don't throw away the dish mover as they can often be refurbished. I just got a duff (not working) Superjack II actuator stripped it down found the problem fixed and rebuilt it! Good as new!
C-Band is VERY forgiving so its all about size! A few dings here and there will not be a problem.
Looking forward to the pictures!
A few dings or dents may be okay but the main thing is that the panels are not warped. You should be able to look across the rim of the dish from the side and it should be flat (no twist). You can "string" the dish to check how true it is. Run 2 strings across the dish at 90 degree angles and if the dish is true, they should
be at the same level. Hope it works out for you.
Good Find
WyrTwister said:
Just scrounged an old mesh dish . Lot of damage . How much damage can a dish tolerate & still give a better signal than mt 90 cm mini bud ?
The mount appears to be for a square pole ? The big set screws might tighten down on a round pole .
Wyr
Geez, people are really finding BUD stuff all around. It would not take me long to accumulate a garage full of stuff if I went out hunting!
Good luck with your new find!
Jeff
Jeff
Heck I got a garage full of stuff, and I don't recall ever going out hunting. :)
I am pretty cheap . Scrounging & EBay are my first 2 choince . :-)
Now a new one , check out Free Cycle for stuff .
Wyr
In the process of scrounging another C band dish
Got the mount , the dish mover and the " button hook ( containing the feed horn & LNB ; before it got too dark to work .
Weather & work schedule permitting , I will go back after the dish , itself , tomorrow after work . Best I can tell it seperates into 4 or 6 sections , like petals on a flower .
This may be a 10 foot dish . Black mesh . Rate the condition of the dish about 8 on scale of 1 to 10 . Do not know if the dish mover or the electronics work , yet . Look like I have at least a 50 - 50 chance of them working .
The condition of the dish I scrounged last night is probably 2 - 3 . :-(
May have a lead on another dish . All through free cycle .
Wyr
Wyr
When you take apart the dish try to mark what panel goes where, it is best to put it back toghther the way it was before.
Good Idea , thanks . :-)
If I get to it early enough this PM , so the light is good enough to see OK , I am wondering If I can seperate it into 2 pieces ? That would eleminate what you are warning about ?
If it is a 10' , the halves would be 5' , might fit in the back of a pick up , over the top of the headach rack ?
Probably less chance of damage if & take it appart in more / smaller pieces ?
Thanks , again ,
Wyr
Thanks , again ,
Wyr
Ya if you can move it in a slice :) two parts that is ok.
10' good condition dish .
Removed the rest of the hardware yesterday afternoon / nite .
Seperated it into 4 sections & got it home tonite .
Wyr
great find!
Wyr[/QUOTELooks like a good quality find at that!!!
Congrats!
jeff
Congrats!
jeff
Thank you . :-)
Hope to get it up and going by some time this weekend .
wyr
Dish mover
Dish mover from the damaged 8' dish will do nothing .
Dish mover from the good 10' dish locked down . Seperated the motor / gear box assembly from the " screw jack " assembly .
The motor runs ( hooked up to a 12 VDC battery charger ) . The screw jack is what is locked down . Sprayed the end with penitrating oil . Hope it frees up by morning .
Wyr
Actuator Exploded Diagram
