C-Band dish positioner
OswaldFTA
70
24
Miami, FL
Hello,
I would need a recommendation of a good and available positioner for a C-Band dish new installation. Is the Mighty Mini ED (Rainier Satellite) any good?
Hello,
Stay away from Ranier, not a good company to deal with. Short of finding one on Ebay, this is pretty much your only choice: PR1200
This one is announced at Ricks satellite and says that works with Diseqc 1.2, what I think is not true since there is no RF connector.
Reactions: FTA4PA
Click on the PR 1200 link above, and you should see a picture showing two F-connectors on the back.
Hello,
find a JGS 1 I may even have new parts for it, water in the water came out, and it did not try to be waterproof as others did no steel parts in it I must have installed 200 of them the worm gear did not break but there was a plastic gear which broke on early ones I may have a few NOS of the gears it would turn using from 12 to 45 volts 35 volts was normal and it worked on 12 foot heavy dishes
Ok, will do. What about the one offered at TEK2000. They say that they "beefed up the thransformer"
I don't know how well TEK2000 can be trusted.
You might have missed this at Ricks, I posted it above. Click the pr1200 hyperlink, I'll also code it so you can see the actual link:
Code:
https://www.rickssatelliteusa.com/pr1200.htm
Is Eutelsat 113 W gone?
Polar vs Az/El Mount
