cann't find t6ku
ccrocket
26
Help me! I have a old primestar dish and hh120 motor with a pansat 3500 rec.. My zip code is 71753 Ture south sat is t6. I went to hock up the motor and rec, when I goto the t6 the rec does not see it. I have a QPH031 Lnb. I need a step by step guid in find the sat. I also need my dish elevasion. I think that my trouble. :mad:
I would remove the motor for now and find and store IA-6 first.
One side (2 ports)of the QPH-031 is linear (marked L) use L.O. 10750
(The other side (2 ports) is circular (marked C) and uses a L.O. of 11250)
Enter a live TP. or channel from IA-6 and point the dish watching the signal QUALITY meter. The signal strength means nothing, just quality.
Here is a strong TP. Channel
DFreq : 11864 MHz (V) SR : 3.515 Msps
Code:
                        Magnolia, AR 71753
          Latitude 33° 15.882'N Longitude 93° 14.352'W
                         Sat Name Sat Lng Az(t) Az(m)   El  Skew
                       Telstar 12   15.0W  96.5  93.9  1.1 -56.2
                     Intelsat 901   18.0W  98.2  95.6  3.6 -55.8
                     Intelsat 603   20.0W  99.4  96.7  5.3 -55.6
                            NSS 7   22.0W 100.6  97.9  7.0 -55.3
                     Intelsat 905   24.5W 102.0  99.4  9.1 -54.9
                     Intelsat 907   27.5W 103.9 101.2 11.6 -54.3
                   Hispasat 1C/1D   30.0W 105.5 102.8 13.7 -53.7
                     Intelsat 801   31.5W 106.4 103.8 14.9 -53.3
                     Intelsat 903   34.5W 108.4 105.8 17.4 -52.5
              AMC 12 & Telstar 11   37.5W 110.5 107.8 19.9 -51.6
                          NSS 806   40.5W 112.6 110.0 22.4 -50.5
                        PAS 6B/3R   43.0W 114.5 111.9 24.4 -49.5
                           PAS 1R   45.0W 116.1 113.4 26.0 -48.7
                     Intelsat 705   50.0W 120.3 117.6 30.0 -46.2
                     Intelsat 707   53.0W 123.0 120.3 32.3 -44.6
                     Intelsat 805   55.5W 125.3 122.7 34.2 -43.0
                            PAS 9   58.0W 127.8 125.2 36.0 -41.3
                         Amazonas   61.0W 131.0 128.4 38.2 -39.1
           EchoStar 3 & Rainbow 1   61.5W 131.6 128.9 38.5 -38.7
                 Estrela do Sul 1   63.0W 133.3 130.6 39.6 -37.5
                     Brasilsat B2   65.0W 135.6 132.9 40.9 -35.8
                     Brasilsat B1   70.0W 141.9 139.3 43.9 -31.0
                 Nahuel 1 & AMC 6   72.0W 144.7 142.0 45.1 -28.9
                        DirecTV 5   72.5W 145.4 142.7 45.3 -28.4
                            SBS 6   74.0W 147.5 144.9 46.1 -26.7
                            AMC 5   79.0W 155.2 152.5 48.4 -20.6
                          Nimiq 2   82.0W 160.1 157.4 49.5 -16.5
                            AMC 9   83.0W 161.8 159.1 49.8 -15.2
                     Brasilsat B3   84.0W 163.5 160.8 50.0 -13.8
                           AMC 16   85.0W 165.2 162.6 50.3 -12.3
                            AMC 3   87.0W 168.7 166.1 50.7  -9.4
              Intelsat Americas 8   89.0W 172.3 169.6 51.0  -6.4
                 Galaxy 11/Nimiq1   91.0W 175.9 173.3 51.2  -3.4
                     Brasilsat B4   92.0W 177.7 175.1 51.3  -1.9
                        Telstar 6   93.0W 179.6 176.9 51.3  -0.4
                        Galaxy 3C   95.0W 183.2 180.6 51.3   2.7
              Intelsat Americas 5   97.0W 186.8 184.2 51.1   5.7
                        Galaxy 4R   99.0W 190.4 187.8 50.8   8.7
                            AMC 4  101.0W 194.0 191.3 50.4  11.6
                            AMC 1  103.0W 197.4 194.8 49.9  14.5
                           AMC 15  105.0W 200.8 198.1 49.3  17.3
                          Anik F1  107.3W 204.5 201.9 48.4  20.3
         DirecTV 6 & EchoStar 6/8  110.0W 208.8 206.1 47.3  23.7
                          Anik F2  111.1W 210.4 207.8 46.8  25.1
                    Solidaridad 2  113.0W 213.2 210.6 45.8  27.3
                         SatMex 5  116.8W 218.5 215.8 43.8  31.4
          EchoStar 7 & DirecTV 7S  119.0W 221.3 218.7 42.4  33.5
  EchoStar 9/Intelsat Americas 13  121.0W 223.8 221.2 41.2  35.4
                       Galaxy 10R  123.0W 226.2 223.5 39.9  37.1
                        Galaxy 12  125.0W 228.5 225.8 38.5  38.7
             Galaxy 13/Horizons 1  127.0W 230.6 228.0 37.1  40.3
 Intelsat Americas 7 & EchoStar 5  129.0W 232.7 230.0 35.7  41.7
                           AMC 11  131.0W 234.7 232.0 34.2  43.0
                        Galaxy 1R  133.0W 236.6 233.9 32.7  44.3
                           AMC 10  135.0W 238.4 235.8 31.1  45.4
                            AMC 7  137.0W 240.2 237.5 29.6  46.5
                            AMC 8  139.0W 241.9 239.2 28.0  47.5
                     EchoStar 1/2  148.0W 248.8 246.2 20.7  51.2
        Satellite Finder is (c) Copyright 2004, P. Lutus
Here is a step by step to set up your motor from Sadoun......
http://www.sadoun.com/Sat/Installation/HH-mount-installation.htm
I am right on the money at 177dec. If my motor is at the same elevation do i need to put my dish and that elecation also?
I would remove the motor and have the dish at 51 deg. elevation. Find and store the satellite then add the motor.
When you have done the above the elevation on the dish will need to be at 25 deg.
And the motor will be set at 33 deg. (same as your latitude)
Hope this helps!
I've encountered some very strange behavior on IA6 Ku.
I have 3 FTA devices, 2 set-top boxes (DMT1050 and Globecast) and 1 Twinhan 1020A.
Using my DMT1050, I try to connect to IA6 Ku for TV Azteca. Of course, I'll try the stronger transponder first: 11864V, SR 3515, the one with the University Network. Lock this TP easily.
But when I try the TV Azteca transponder: 12076V SR 8741, I get very strong signal, but the quality stays at 50% (on the DMT, it means it's getting close but no cigar), no luck locking it no matter what I tried. Tweaking the dish, turning the LNB, nothinig.
Getting very frustrated (I've tried this for weeks), so I decide to try the same thing on the Globecast receiver. To my surprise, I can lock the Azteca transponder easily, but no matter what I do, I can't lock the Univeristy Network transponder, which is supposed to be the stronger TP.
So I try it on my Twinhan, same result as the DMT1050, lock on the University Network, no luck on the Azteca.
I try this without any DiSeqc switch, just straight LNB to receiver connection.
Now this is very strange. Does anyone have similar experience?
pansat 3500 alignment??
Difficult Dish Fine-tuning
