Can't log in to DRA - Is DRA still supported?
Tony S
1,502
934
Hills of Eastern CT
I just tried to log in to the Dish Remote Access (DRA) site and I can not log in. The message onscreen says: "The system is currently unavailable, please try again later". Dishonline works fine. Did Dish finally take down the DRA site like it has been threatening to do for the past year?
This is the link I was using for DRA. Does this work for anyone else?
https://my.dish.com/customercare/equipment/processSatTimer.do
Dishphreak, I tried the link you posted and I still can not log in. Using that link, it keeps telling me that my password is incorrect even though it is the same email and password that I have always used to log in for both DRA and Dishonline.
I tried this AM, also using the dish sling url. Got the message that it was no longer supported and did not get the option to continue. Was redirected to the Dish Online url. Was able to access my sling and the dvr after it installed a new add on in Firefox. Have a video from the dvr on my laptop right now. Used my dishnet log on and password.
Say goodbye to being able to "resume" a DVR recording where you left off. I don't know why that's such a hard feature to implement given they had it before with DRA. Guess it's just the mobile apps for me from now on. : (
The dish.sling.com website will work if you log in using your Dishnetwork email address on file, not necessarily your username/email address. (My username is still my username, so I don't have this confusion.) When the popup pops up to tell you to continue to DO, just cancel the window and continue with DRA.
I did try to log in using my email address and password. It does not work using the link that Dishphreak posted. It tells me that my password is incorrect. I can sign in to both the Dish Network site, and to the Dishonline site using the same email address and password. I used to be able to log in to DRA (using the link I posted in the 1st post above) with the same email address and password (then the 'Do you want to use Dishonline instead' pop-up appeared and I just canceled the window and continued with DRA like you said).
Tried again just now and it worked. I'm looking at the old DRA website on dish37.sling.com.
The back door at dish.sling .com should work if you have an identical username email address and password setup at SlingBox .com.
The mismatch is because of the authentication methods they were using, I don't have the detail, but it seems that when we would login at DishNetwork, it handed some sort of trusted token over to the dish.sling .com servers. Since DishNetwork isn't currently doing this.. it means you have to have had a valid Slingbox user/pass ... and by making them identical to dishnetwork, that perhaps that was what allowed us in and allowed the back end servers to recognize the *dish* side of things.
There was a user that tried this.. and is being given a setup/activate web for the dish receiver ... after they setup their account at Slingbox and then tried dish.sling ...
The only thought was that since they'd never used dish.sling directly, that they may have had to prior, so that both sides would know the user/sling abilities.
In any case ... try it too .... go to slingbox setup the same user/email/pass and see if you can get in..
I tried creating an account via Slingbox.com and then logging in with dish.sling.com and all I got was the following error page:
Warning: mysql_connect() [function.mysql-connect]: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /var/www/html/includes/db.php on line 70
Error connecting to mysql
I tried again the old way through https://my.dish.com/customercare/equipment/processSatTimer.do and I can log in just fine, but it's to a page that says:
The system is currently unavailable, please try again later.
I have the same results as Nominal.
The dish.sling.com link that bhawley posted above takes me to the same log in page that Dishphreak posted in post #2. Using that link, it keeps telling me that my password is no good, even though I am using the exact same email address and password that I have always used on the old DRA site and the Dishonline site.
DRA hasn't been supported for a long time now.
Its just that the work arounds people have been using to get to DRA now no longer work.
Did you follow TG2's advice and verify you are logging in to dish.sling.com with the same credentials as you use on slingbox.com?
Everybody please look at your "Email address" under My Profile on the new MyDish.com website. Note that your "Online ID" is a separate line item and (in my case) is different. If you are entering your OnlineID in the DISH Remote Access Login site, this will not work and has never worked.
I don't know the deal with why some are able to connect to the old DRA site and some aren't, but when I login at https://my.dish.com/customercare/equipment/processSatTimer.do this is what I get: DRA.jpg
Also, after registering at Slingbox.com with identical credentials to my Dish account and going to dish.sling.com, I got directed to a screen requesting receiver info and after filling it out I get directed to an error page.DishSlingcom.jpgDishSlingcom2.jpg
BBMP not a good deal
TV Everywhere Trial today
