GEOSATpro Can't put back user file
monz
28
Repentigny, Québec
I've saved my channel list on an usb key, tranfered it on my computer. After, I insert some channels manually with Ali editor, saved and put back on an usb key, the receiver seems to do as if it was an abs file. It reboot and brings back the problem i had last week (reboot out of control).
I got it back to life a few times with the recovery cable with the same result every time.
I also tried to put the udf file with the cable but the receiver reboots out of control.
I also tried to pull out of the list the new channels with Ali to create an old/new file... no result.
At the moment, It's on with the latest firmware and no channels.
It's a bit frustrating. :(
Reload the latest firmware .abs file then perform a Factory Reset BEFORE scanning, attempting to save or upload the .udf to a PC via the ZTTL/USB convertor.
Where did you download the ALI Editor software? Is it the microHD version from this forum?
What is the chip type in the ALI Editor configuration settings file? Chip Type=M3601s? Configuration Setting file then saved as read only?
What type of file did you save using the microHD? .udf?
What type of file did you save using the ALI Editor?.udf
Alternately, if the installed .udf has been corrupted, open the new firmware .abs file as Default Data Base file type, then export the satellite/transponder list as type User Data Base .udf. This .udf is then the exact copy of the default data base compiled with the firmware release.
I have the Satellite guys Ali Editor, I've saved uploaded, saved in .udf. I've tried all you suggested but nothing worked.
I'll rebuild by scratch. It's O.K.
It was working well with the latest uptade and I'll keep it that way for a long time.
Thanks anyway.
AZBOX Trying To Connect AZBox Premium + To Verizon FiOS Router
GEOSATpro Geosatpro-problem-manual updates
