So I finally got my Cband setup this weekend going. (10 foot Pinnacle) After getting HOA approval. I will post lots of pictures. So far its been straight forward. I quick created the pole last week with 3 80 lbs bags of quick crete. The pole is about 5 feet into the ground and is in solid footing. Attached the reflectors together this week making sure they snapped into place as well as screwing them. I set the elevation and declination levels on the latitude head, then attached the buttonhook to the reflector. I also set the LNB 33 and 3/16th's per manual. I split the difference as I have a Chaparral feed horn with no golden ring. I will adjust when I tune it up later on in the week. I then attached the latitude head to the pole and then the reflector. Once that was all settled, I began the process of wiring and ran out of time tonight. Wireing is going to be the easy part. In the next few days I will have to get this guy on the ARC and I should be good to go. It wasn't too bad putting it up. Just heavy.
