Comments from a newbie to FTA
Nice — glad you found a cable that works. That camcorder cable working, and the one you bought earlier not working, is exactly the pinout problem primestar31 was pointing at: those 3.5mm AV jacks all look the same, but video, left, right and ground are wired in different orders depending on the brand, so one cable gives you a picture and another gives you nothing.
The mono audio tells you what that camcorder cable is: video plus one audio channel only. If you want stereo out of the same jack, the cable lost_mesa mentioned — the one that came with the GEOSATpro MicroHD — is a known good match for the V9 Prime, and it's worth trying that pinout first before buying another generic cable. If a stereo cable gives you a black-and-white picture or sound on only one side, the rings are swapped, so try another cable rather than assuming the receiver is at fault.
Two small things that help with composite on the V9:
- Set the video output to 480i (or 576i) in the AV settings. Composite looks a lot cleaner at native SD than when the box tries to downscale a 1080p picture.
- The HDMI audio extractor idea from earlier in the thread won't help this particular box now, since your HDMI port is dead — the analog jack is the way to go here.
Good save on the camcorder cable — those old cables are getting hard to find.
Reactions: k4otl
Thanks! It was a camcorder of my parent's that they don't care about, has old tapes of Christmas when I was a boy and such. All in the nice original Sony case. The cable was intended for plugging the thing into the VCR and recording/displaying on the TV. I think the generic cable I bought isn't "long enough" for the ground ring and so it causes all kinds of buzz and interference. Thankfully I have a perfectly normal V9, and the dead-HDMI V9 as a backup.
kU 5g Interference
