I don't think we are disagreeing very much. If you are close to the transmitters, close enough that "rabbit ears" will give a very strong signal, then the CM4221 might be OK (hence my suggestion to Dave). And having the wider beamwidth is certainly an advantage sometimes. Dave has almost every station in one place, Mount Wilson, so having a wider beamwidth is no help to him. And as Rick posted, the gain on the CM4221 particularly in the lower part of the VHF-hi band is very poor. But that does not mean it won't work in the right circumstances. I have seen posts from people getting OK reception on the higher VHF-hi channels with the CM4221 at 20 miles from high-powered stations.
There is no doubt however that the CM4228 is a much better antenna if you want acceptable VHF-hi performance from a UHF antenna.
You could of course use a VHF-UHF combo, but they are SO large, because they have to receive VHF-lo as well (although I did see a mention somewhere of one new combo antenna just for UHF and VHF-hi, can't remember what it was). Or you could couple a VHF-hi antenna to the CM4221.
