Dang it, Ice! Ya threw out the baby with the bathwater! -
We had this great off-topic discussion started in the middle of what turned out to be a hacker thread!
Darned good thing I kept a copy, huh?
Using a Dish Network DP-34 Switch for FTA
First, the switch is a big heavy monster, with tons of F connectors.
Built like a brick ... out house.
Could probably drive over it with your car and not hurt it!
Has three inputs, four outputs, and can be cascaded with a 2nd unit for 8 outputs.
Possibly to as many as 12 outputs, total.
Dish folks throw them away ! -
Cadsulfide documented how he was using it in an unusual way, and I wanted to preserve that idea.
I think he used it as a heavy-duty 3-in, 1-out diseqc.
Here's how the discussion went:
Try a DP34, bulletproof 3 lnb in 4 recievers out. Only need to use one lnb.
but that only works with stacked LNB's
But the DP34's work with the QPH031 right?
nope..the QPH is not stacked...very few KU LNB"s are stacked
I guess the big question is do you know what youi want to do in your head?
Then we might be able to give better answers
Ice,
I have a BSC421 C Band on Port 1, a DN FSS linear on port 2 (123), and a red 0.2 db linear on port 3 (125) of one of my DP34's and two generic linear lnbs and a Norsat lnb on the other. I get all the transponders and both polarities on both DP34's with no problems.
Do you have more than one receiver connected to any of your DP34's?
The DP-34 is just a big diseqc switch (with amps, and more)...
But in its normal configuration, all the receivers supply around 19 or 20 volts to the switch.
I was under the impression it was intended to operate only at the higher voltage.
But it's not like anyone publishes a spec sheet on it.!
If any of the connected receivers supply 18 volts for Horizontal polarity, that might propagate to all inputs.
It certainly should.
Likewise, I believe all LNBs are powered 100% of the time.
That's a big load on most DVB receivers.
I haven't taken a DP34 apart nor tested it outside its normal operating parameters.
You apparently have.
I wonder what loophole you have found . . .
