dtv stacked system
servicetech
Nov 26, 2009
4
Gainesvile, FL
dtv stacked system
one of the mdu's i service just received a new batch of d-12 100. the New Guided Setup & Installation Verification much different then in the past. i am unable to pull-up the diagnostic menu to change the lnb mode from unstacked to stacked. i would press the right arrow and active button at the same time, that would pull up the menu. dtv tech support had no idea?
It's hidden in a different place. I read about it in another forum a few days ago. I'll poke around a few of my other hang-outs and see if I can locate it.
Try this, from Randon Joe, a new member at DBSTalk:
D-12 Models
D12-500s (YMMV, but I suspect any D12 with the latest firmware from the factory will do this) require you to press [Right Arrow] + [Active] at the Language Select Screen, which is the very first screen of the configuration. Only on this screen can you reach the LNB Setup menu.
R-16 Models
R16-300s required a force download. From what I've heard, the download comes down off transponder 2. Even if you you are on a stacked signal (where the receiver would not normally see transponder 2) it will still complete a download. From there it is a similar setup; [Right Arrow] + [Active] at the Language Select screen.
HOW TO: Change LNB setup for newest DTV firmware - DBSTalk.Com
dtv stacked system
dtv stacked system
merged all your posts into one thread
DO NOT CREATE MULTIPLE POSTS OF THE SAME THING IN DIFFERENT AREAS
Change SlimLine to SWM - off-air question
CEO email
