H398 Software Version
dweber
1,882
2,760
Plain City, OH
I manually updated both of my Hopper 3 receivers to H398. Both of my Joey 3 clients stayed at J596. After the update caller id and tv enhancements got shut off on my one Hopper 3 receiver.
Anyone else notice volume on locals lower than the satellite channels? Since I updated H398 Wondering if just my market area. I have an OTA local that is fine so I know it's not my receiver
Just the opposite for me, but occurred before H398 was installed. About a 10dB increase based on my Yamaha receiver volume settings. A welcome change since almost all streaming services are at least 10dB lower than most of the dish channels so have to crank up the volume to hear anything.
Hopper 3
Yamaha RX-A3080
Amazon prime, netflix, peacock, hulu on firetv 4k stick connected to Yamaha vice tv
Sent from my SM-X800 using Tapatalk
brittanygarden
With H398 on the Hopper H3 and P13712 on the Hopper Plus, three issues still remain:
Issue #1
With a Hopper 3 and Hopper Plus setup, I can see somewhere after P13402 and P13712, the settings cogwheel when one hits the Home button is no longer on the right hand side but now closer to the left center of the screen and the text for things are small. One thing I noticed in H398 which existed in H397 from H392 and P13712 from P13402 is that I keep my Hopper 3 on never inactive so it's always on but if I turn off my TV using the TV power button on the 50.0 and 52.0 remotes and then turn the tv back on, the Hopper does not seem to stay on the last watched channel before the tv was turned off but instead, it is on channel 101 which is DISH Scapes. I tested this by turning the TV off and then back on 20 seconds later with the same exact same results of it going to channel 101 when the tv is turned on again.
As I mentioned in the H396 thread about H397:
"I decided to unplug the Hopper Plus, unplugged the Hopper H3 power cord for 1 minutes before plugging it back in, everything works correctly so when I power off and on the tv with the DISH 50.0 and 52.0 remotes, it remains on channel 626-05 which is a streaming channel. However, the HDMI-CEC set to on when I have the tv on another input that is not the Hopper H3 and hit SAT on the DISH 50.0 and 52.0 remotes while the TV is on, it does not do anything. When HDMI-CEC is set to on with the Hopper Plus connected and when I have the tv on another input that is not the Hopper H3 and hit SAT on the DISH 50.0 and 52.0 remotes while the TV is on, it would switch to the input the Hopper H3 is connected to.
After I plug the Hopper Plus back into the Hopper H3, the results are different depending on what channel I am on when I power off and on the TV with the TV power button on the DISH 50.0 and 52.0 remotes:
1) If I was on Channel 626-05 which is streaming before the tv was turned off, with HDMI-CEC turned on and then hit TV Power on the DISH 50.0 and 52.0 remotes, it would be in standby mode and ask to hit the SAT button which I hit and it's on Channel 101 DISH Scapes
2) If I was on Channel 626-05 which is streaming before the tv was turned off, with HDMI-CEC turned off and then hit TV Power on the DISH 50.0 and 52.0 remotes, it would be on Channel 101 DISH Scapes.
3) If I was on Channel 252 which is streaming before the tv was turned off, whether HDMI-CEC is on or off and then hit TV Power on the DISH 50.0 and 52.0 remotes, it would be on Channel 251 which is non-streaming.
4) If I was on Channel 251 which is non-streaming before the tv was turned off, whether HDMI-CEC is on or off and then hit TV Power on the DISH 50.0 and 52.0 remotes, it would be on Channel 251 which is non-streaming.
So the problem is definitely with the Hopper Plus connected to the Hopper H3 while the Hopper H3 without the Hopper Plus connected works fine other than the HDMI CEC set to on issue mentioned.
Also want to mention that with the Hopper Plus (Software vP13712) connected to the Hopper H3 (Software vH397) with HDMI-CEC set to off and the TV already on and watching 626-05, all I had to do was using the DISH Remote (50.0 and 52.0):
Hit Home, selected the Gear on the screen which goes to the Settings menu, then "Device Preferences", About, Software Update and then return from there and it would also have gone back to Channel 101 DISH Scapes." These issues still occurs in H398 and is probably a issue with the Hopper Plus software as that still did not have a new version after P13712 yet.
Issue #2
As mentioned in the H396 thread about the Hopper H3 with H397 software and Hopper Plus with P13712 software:
"Experienced an issue with Channel 626-05 yesterday which is a streaming channel so basically, this is what happened. The current time was 8:10PM San Francisco time and the program schedule is as follows:
1:00PM-3:00PM, 4:00PM-6:00PM, 6:00PM-7:00PM, 7:00PM-8:00PM and 8:00PM-10:00PM
so basically I had paused earlier during the day so 8:10PM was basically showing what was at 7:50PM. I hit replay/rewind, it goes to 8:00PM and then jumps to 6:00PM, it appears the buffer goes back to 1:00PM as I can play everything up to 6:00PM from 1:00PM but from 6:00PM, it is missing everything from 6:00PM-8:00PM as it will go from 6:00PM to 8:00PM as 8:00PM is the start time of the current show. Assuming the time was still 7:59PM, I can go all the way back to 7:00PM without issues but the 6:00PM-7:00PM would be missing.
This is with Hopper software H397 and Hopper Plus Software P13712" - Not sure if this is a issue is with the Hopper H3 software, the Hopper Plus software or both Hopper H3 and Hopper Plus software.
Issue #3
The screen that shows up here, which is after hitting Home on the DISH Remote (50.0 and 52.0), where I have the arrow pointing in the photo below, isn't that supposed to show something like the Weather instead of what it is showing as when I click on it, it does show the weather in a bigger full screen for San Francisco on The Weather Channel:
This still occurs in H398 and is probably a issue with the Hopper Plus software as that still did not have a new version after P13712 yet. Not sure if the Hopper H3 without the Hopper Plus connected even has the weather icon at all.
Many thanks for your help!
I have the same issue with the weather not being shown and showing that wifi looking icon.
Is that with the Plus or without the Plus?
Mines did fix itself once right before I updated to H398 as mentioned in the H396 thread. charlesrshell did show his was working in H397 withe the Hopper Plus also on P13712 but I wonder if his works correctly all the time or if it actually had the problem too and also just fixed itself when he went to check it.
I don't ever recall seeing the WiFi icon. I just checked again and I see the Wx icon for both my H3+, H3, and all my Joey 4s.
brittanygarden
Issue #1
Issue #2
Issue #3
brittanygarden
There is also another new issue that only occurs in H398 as mentioned below:
Issue #4
Ever since I upgraded to H398 on the Hopper 3 with Hopper Plus on P13712 on August 8, 2025, this did not happen on the Hopper 3 with H397 and Hopper Plus on P13712.
The first time was on August 12, 2025 when I was watching channel 626-05 which is streaming TVB Drama that is part of the JadeWorld package. The video would freeze and not resume even after 30 minutes. The other JadeWorld streaming channels are working fine but channel 626-05 would show the DISH Animated logo of starting the stream but no video would show and then the following error would show up on the screen no matter how many times one tries to change to channel 626-05 after going to another channel:
On the August 12, 2025 incident, I thought it was a channel outage so I contacted DISH on Facebook Messenger and the only way we were able to get the channel back was to use Reset Hopper in the Tools area of DISH Diagnostics.
The same thing happened yesterday and the video would not resue even after 30 minutes. The other JadeWorld streaming channels are working fine but channel 626-05 would show the DISH Animated logo of starting the stream but no video would show and then the same error with the 2008 error code
would show up on the screen no matter how many times one tries to change to channel 626-05 after going to another channel and the only way to get the channel back was to use Reset Hopper in the Tools area of DISH Diagnostics.
I do not know if rebooting the Hopper Plus would have fixed the problem or not.
Many thanks for your time in reviewing this!
Makes one wonder why it works for some and not others. If I had to guess, it seems like it might depend on the Hopper 3 with or without the Hopper Plus's is connected to the internet before the weather part loads and if it is connected, then it will work and if it is not, then it will show that issue. What appears to be missing is that icon needs to learn how to refresh itself and check for internet connectivity again later on and update the icon if the internet is connected as I do notice the Bell on the right hand would have a notification claiming no internet connectivity and then another one saying there is internet connectivity.
brittanygarden
Issue #1
Issue #2
Issue #3
brittanygarden
Update on Issue #2:
As mentioned:
"Issue #2
This is with Hopper software H397 and Hopper Plus Software P13712" - Not sure if this is a issue is with the Hopper H3 software, the Hopper Plus software or both Hopper H3 and Hopper Plus software."
What I found more interesting is that if I did play from 1:00PM, it will actually play all the programming from 1:00PM-8:00PM including the missing 7:00PM-8:00PM programming but that will basically be at 1:00AM at night so apparently, it's holding the streamed content somewhere since at that point in time, it's actually holding 12 hours of content, the 1:00PM all the way until the 1:00AM content.
My bad, the latest H398 update has made the IP pairing capabilities of Logitech remotes to fail. If you attempt to re-pair a hub based Logitech device on a Hopper 3, the scan fails to find the Hopper. Haven't ever had an update before cause the Logitech remote to unpair. Affects Logitech 900, 1100 and Harmony elites for sure.
As the proud owner of two Harmony Elite remotes that now don't work, is there any fix for this problem yet? I thought the problem might be with the plus box so I tried to disconnect it. (Removed connections between plus and hopper and restarted hopper), but I couldn't get the Hopper to reconnect. Obviously, I missed a step or two. Can anyone give me some instructions on how to remove the hopper plus and just use the h3 as a stand alone receiver? I never use the plus anyway and if it is the problem I would be glad to be able to use the Harmony Elites again.
As an after thought...the Harmony does still work normally EXCEPT with Dish's equipment.
Switch the HDMI cable from the + to the H3 and just unplug the power brick from the +, You don't have to unplug the usb cable. Don't reboot the H3 you will have that blue screen just wait the H3 will reboot on its own it may take 10-15-20 minutes to reboot, after reboot if you get a no signal popup hit guide go to a channel you know enter.
Do the procedure exactly like Partysox says and report back with your positive result, 😀
I still use the Harmony with Dish and other equipment. Not useful with the Roku Ultra.
I bought two 650s as backup. Can't find them. Sigh.
I use my Harmony 665 with my Roku Ultra all the time, no problemo. You just have to have good straight visibility between the two and the Roku is very fussy about a direct shot. Also he is having issues with his Harmony and the Hopper+. This issue will never go away because the Hopper+ is Android and Google insists that any remote must have voice command. The Harmony's do not.
hopper plus PIP question and a couple others..
Wireless Joey or other option for new tv in sunroom
