Has my Hopper 3 Bit the dust? Will my Timers carry over?
Kev7274
49
40
NC
Storm come through and caused a Loud Pop from the Hopper. Sounded like a Fuse or Capacitor blowing. Tech is coming in a few days
to replace the Receiver I guess,not sure why they don't just send me a new one.
Not too concerned about the recordings,but I have alot of Timers. Since I did use the Hopper 3 remote a few days ago,will the timers carry over to the New Receiver?
I thought about seeing if I could just hook up the Hopper drive to my PC and try to move the contents over to an External,but wasn't sure if I should or if it would even work.
When you get your new Hopper 3 have the tech do a Restore Settings from the original remote. I believe the 54 remotes do auto saves from time to time.
Also, keep in mind that the new Hopper will take a few days to settle in, so you may not see those timers for a little while.
That would be great. I usually use My Harmony remote,but it finally went bad and I had to wait on another one. During that Time I had to use the Hopper remote for a few days. Hope it did an auto save.
Do you keep your 54 remote battery fully charged? By that I mean do you replace batteries from time to time. I also use a Harmony remote but keep the 54 remote charged and close by for those few times that I may want to use the voice function.
I did replace the batteries the other day when I had to use it,but I did that just because I hadn't replaced them in a while. Not sure if they were actually bad or not.
When you get your new Hopper 3 you can see how your remote batteries are doing at any time, charge wise, by pressing Home 3 times on the 54 remote or Menu 3 times on your Harmony.
The remote actually changes rx settings and initiates timers by itself?
Also don't get why DiSH is actually sending a servicer like they always should but don't. They have always just relied on torturing the cx to do his own rx swap and then dealing with any ensuing issues if/when they get a call....they even modded all the rx's to remove setup functions and have them "automagically" install, which in turn tortures dealers/servicers who would rather just have the direct setup capability.
It does, or you can go back to that same menu and restore settings to Hopper
Dish Survey on New Guide
OTA CBS channel thinks it's FOX in Indy
