hd tv tuner
R0ss
821
Ayer, Ma
It appears that the atsc tunner in one of my flat screens is dead. Not sure why or what happened as i just recently put up an ota antenna. One day everything was good then nothing then it was back and the n nothing. Changed cables etc then hooked it up to 722 and voila OTA.
I figure a standalone atsc tuner will be cheaper than a service call any suggestions?
By the way the ntsc tuner works fine.
Ross
Ross
Sent from my rooted DROID RAZR Maxx using SatelliteGuys
The trouble is in finding a standalone ATSC HD tuner. They are kind of rare. You can use a DTV or DISH box if you subscribe. A TIVO unit has one, but also requires a subscription. The Channelmaster DVR has an ATSC tuner as well. Radio Shack sold one several years ago, but it has been discontinued for some time. Magnavox has a DVR/DVD Recorder with a built in ATSC tuner that Amazon sells refurb. Any of these solutions will cost a couple hundred dollars.
After i posted i took a quick look on craigs list. I just missed a used tivo wofe lifetime subscription. Guess i will just keep my eyes open.
I do subscribe to dish and thats how i have it hooked up now and how i determined the atsc tuner in thw tv is dead
Ross
Unless your flat screen is under warranty just use it as a monitor for the DISH receiver. Prices on new flat screens have dropped to the point that repairs may be just a waste of money.
I agree
Ross
Remebered I bought a VOOM stb a few years back. It was one that "should" work for OTA. Never tried it out at the time. So I pulled it out did an inet search to be sure I had basic instructions hooked it up and much to my disappointment no out put at all, just a blank screen. I'm using component out just to test as I don't have a dvi to HDMI, is output automatically selected?
I' figure it was doa and that is my own fault but if It worked it would solve my problem.
Ross
Ross
So I tried again...the ota module wasn't in tight. Unit fires up I can scan for channels but once I'm done it goes to a screen tbat says voom not authorized. So far everything I can find indicates if you can get to the instalation menu and scan for channels you are good to go. Anyone have a clue?
Ross
I recall that the Voom boxes were quirky in their OTA reception. Samsung made several different HD tuners. I've used 3 different models from them and one from LG. My current favorite is the DTB-H260F from Samsung. I saw one on eBay for about $120.
The older SIR-T451 was a good unit too. They appear to be less expensive on eBay.
Ross
Ross
So I read through just about all the posts on the VOOM stb on the archives and it seems that even though I can access the instalation wizard, scan for and save to memory my local OTA channels it would appear that the fact that once that is done and i press watch the screen then says VOOM not authorized. Guess I bought a door stop. Again my own fault for trusting the seller....
I was under the impression that I wouldn't even be able to scan OTA if the box wasn't authorized oh well...
Ross
I have the Samsung DTB-H260F, which is great. Also have the Zenith HDV420, which is in the attic, but is also a great box. Both are obsolete now, tho. I think the performance is miles better on the Samsung tho, plus it has a guide.
My local RTV replaced by LWN
Need to combine 2 separate antenna signals.....
