help twinhan 102g
gitch
7
I just purchased a twinhanpci 102g card and have scanned with no luck. I have a signal strength 0f 40. I have a old DSS dish with lnb and also a dish 500 with lnb. I have no idea what i can pick up. I live near windsor, Ontario Canada if that helps.
Thanks, any help would be appreciated.
pointed at 91w what sats can i get
i have my dish 500 pointed at 91w tried galaxy 11 scanned and nothing not even radio i believe it is my settings. i have a twinhan 102g. is there any better software out there. right now i have prog dvb and my theatre.
Dish 500 will not work for FTA if it uses a switch (some in built). If there is no switch and its not a Dish Pro LNB it can be used as a single dish pointing at any of the above satellites for the LEGAL FTA channels.
okay 12223 is the freq i would enter to get the bell express preview channel for 91w right. do i enter this into the lnb freq or the transponder freq
Transponder.
If its a regular DBS LNB then the L.O. should be 11250
Moved thread to the PC DVB area.......
ok. i will try both dishs just in case the dish 500 has a switch built in like you said it may not work.
so i can use my old dss dish and lnb if needed.
i have it pointed to 91 west right now.
i believe lyngsat sais i pick galaxy 11?
I am using Prog DVB.
Quality is zero and level is 34% and the next part is my prob, the settings.
LNB - gives me a bunch i pick galaxy 11 as per lyngsat?
Transponder -- 12509-v-6283 ?? i dont know which one gives me about 100 to pick from
then
freq?? polarisation?? and symbol rate??
thanks, i know i should figure this out myself but its been three days i am confused more than ever
Stacked dish 500 Digital LNBF will it work on FTA twinhan 102g
I have a stacked dish 500 and it sais Digital LNBF on the LNB will this work or does it have a built in switch? And therefore not compatiable with FTA. if so my lnb of my rca dss system sais DSS digital satellite system i believe it should work with my twinhanDTV 102 g card?
Any ideas
110w with twinhan
could someone help with settings i am using a rca dss dish and lnb. i have tried to understand lyngsat but do not get any channels. i do i need to use twinhan software or can i use progdvb?? i can never get the settings proper. i am pointed 110w get someone share there settings if they own a twinhan card or have used progdvb please.
I PM'd the OP and he has ASSURED me he is just trying to get his new card working on ANY satellite with the antenna he has at hand. Re-opening.....
"Just to make it clear i just bought this card from ebay and my uncle has a motel with one of those huge dish's. I would like to make sure the card works because he previously said he would like to sell the dish because he is getting a new one. So i just need help because i have scanned with no luck. I hope this card is not defective it was sealed."
The twinhan software sucks, and I've never used progdvb. Download ritzdvb (free) or MyTheatre (free with 1 hour limit until you buy it).
For ritzdvb, make a new text file in the transponders folder, and copy the following into it:
Code:
[SATTYPE]
1=1100
2=Echostar 6,8
[DVB]
0=32
1=12224000,V,20000000
2=12239000,H,20000000
3=12253000,V,20000000
4=12268000,H,20000000
5=12282000,V,20000000
6=12297000,H,20000000
7=12311000,V,20000000
8=12326000,H,20000000
9=12341000,V,20000000
10=12355000,H,20000000
11=12370000,V,20000000
12=12384000,H,20000000
13=12399000,V,20000000
14=12414000,H,20000000
15=12428000,V,20000000
16=12443000,H,20000000
17=12457000,V,20000000
18=12472000,H,20000000
19=12486000,V,20000000
20=12501000,H,20000000
21=12516000,V,20000000
22=12530000,H,20000000
23=12545000,V,20000000
24=12559000,H,20000000
25=12574000,V,20000000
26=12588000,H,20000000
27=12603000,V,20000000
28=12618000,H,20000000
29=12632000,V,20000000
30=12647000,H,20000000
31=12661000,V,20000000
32=12676000,H,20000000
[LNB]
LOF1=11250000
LOF2=11250000
LOFSW=0
DiSEqC=NO
DiSEqCType=0
If that doesn't work, then you have a dishpro lnb which bandstacks, so copy this instead:
Code:
[SATTYPE]
1=1100
2=DP500-Echostar 6,8
[DVB]
0=32
2=13361000,V,20000000
4=13332000,V,20000000
6=13303000,V,20000000
8=13274000,V,20000000
10=13245000,V,20000000
12=13216000,V,20000000
14=13186000,V,20000000
16=13157000,V,20000000
18=13128000,V,20000000
20=13099000,V,20000000
22=13070000,V,20000000
24=13041000,V,20000000
26=13012000,V,20000000
28=12982000,V,20000000
30=12953000,V,20000000
32=12924000,V,20000000
[LNB]
LOF1=11250000
LOF2=11250000
LOFSW=0
DiSEqC=NO
DiSEqCType=0
I stole these from the ritzdvb website. They have other ini files for other FTA birds once you get your setup working. Of course you'll need a bigger dish and linear lnb!
ritz dvb
thanks could you give the ini files for ritz dvb for a rca dss lnb please i am trying that lnb because it is not stacked and i am pretty sure i will have less probs
thanks
Losing 1.2 setting
Do I want a FTA receiver?
