Well, I finally experienced issues with an internal drive. My owned H3 came with a Seagate ST2000VM003 drive with a 2019 build date. Suddenly one morning the DVR functions were unavailable and the screen showed "HDD Warning 760 - The content on your hard drive has become corrupted and will cause your receiver to function improperly. In order for your receiver to function properly all content on the hard drive will need to be deleted at this time. We apologize for the inconvenience." with an OK button. Well, at least they apologized. Instead of pressing OK, I tried a few power cord reboots as well as restarting through the diagnostics menu, but no change. I also tried running the system checks inside of diagnostics and it instantly reported a status of 100 on the hard drive test. In this case scoring 100 is bad. Finally I decided to press the OK button and I got a message about the hard drive being successfully "cleaned". I felt comforted now having a clean hard drive.
A couple of observations:
1. Despite not having any hard drive functions, multiple tuners remained available on the Hopper 3 and on the 4K Joey that I use frequently. Kudos to Dish for that.
2. It would be nice to have more information about the unclean hard drive and possibly be able to clean just the "dirty" parts instead of losing all recordings.
3. It would be nice to have information about the code 100 reported for the hard drive on the diagnostics with a red X and the ability to run some non-destructive checks and repairs on the drive.
4. After the "cleaning" the drive seemed to function normally.
Of course, now I didn't trust that drive. I ordered a "new" ST2000VM003 and installed it. This drive turned out to have a 2012(!) build date. I hear those were the good ones.
No issues, H3 started right up and the new drive was available. Additional kudos for how easy this is. I'll now keep the old drive on the shelf as a spare. I might try putting it in an enclosure and running some tests on it, but I don't want to do that now.
Just to test things out, I tried transferring some recordings from an EHD to the H3 with the new drive. I got this helpful message: "The transfer completed with errors." None of the recordings appeared to have been transferred. Not knowing how to see what these errors were, I tried running the system check and of course it reported that the hard drive was OK. Some kudos were retracted.
I then tried making new recordings on the DVR, transferring to the EHD, and transferring them back. These completed without error.
It seems that maybe the H3 prevents transfer of recordings from an EHD to a Hopper 3 with a different drive than the one that was used to transfer them to the EHD originally, but I don't know.
The internal hard drive diagnostics and reporting functions on the H3 could use some work. Should I hold my breath? Maybe some Satellite Guys out there have some insight.
