HR-22 season recording problem
terry1
21
:mad:I had set up my HR-22 to record all first run episodes of Crash on Starz.Well it was going along great then about 2/3 thru the season it skipped,did not,record two new episodes in a row.I figured that maybe it was a glitch that would not happen again.
I was watching WE network,that right WE,I saw a Hopkins episode and deceided to record all episodes, first run and reruns("BOTH").Well it would not record anything but first runs,I know for a fact because I would see the edisodes on my guide and actualy watch them live.
Just recently I noticed a doc on the trials of Ted Haggard on HBO; so I decieded to record all, if more than one episode,first run.Well it recorded it every time it was on.After ten times,I gave it a chance to redeem it's self,I cancelled the series.
Any one else having similar problems?
try to hit the menu button and select manage recordings. Check the to-do list to see if a program will record. also check the prioritizer option and see what can be done in there. The only other thing I can say is to reset you receiver to the factory defaults. hit menu-setup-system setup-reset-reset everything. but by doing this you will lose all your recorded programs and would need to set everthing up again.
Thanks"dtvpimp'' for the input.All though I had the above mentioned programs set to record,they were did not apear on my "TO DO " list.
I don't believe the priority of the program(s) will come into play unless the HR-22 has to make a choice,then it will record the most/highest priority program.
Still wondering:cool:
I had a similar problem with my hr-21 last week.
It seemed to take a few days for the receiver to parse through the guide data and figure out what it was going to record. Hopefully time solves the problem for you.
