According to your ZIP code, you would be getting the Marquette locals that are only on 61.5W so it would appear that you chose to install the wrong dish or you're pointing it at the wrong satellites.Only issue so far is I'm not getting any of my local channels? CBS, NBC, ABC? Any ideas before I call Dish about it?
DISH Customer Service isn't prepared to help you with a failed self-install. So-called "Professional Installations" have been the order of the day for many years now so they don't have the expertise to bail you out.
After all that and to end up with SD LIL. Oof!SD locals are on 129 Just call and tell them to turn your locals on.
Absent an external switch (DPP44), the DISHPro+ LNB (marked dpPlus) puts all three slots on a single cable. If it has been refitted with a DISHPro LNB, you're in for even more suffering.How do I aim at more than one sat with just one RG6 cable ran to the 1000.2? Can the 1000.2 dish be used for the 61.5 sat?
When I cover up my outside eyeballs I lose signal with the sat and no matter how I move it I cant get anything about 0 signal strength. If I leave them uncovered I can pick up EchoStar 119 West with ease. Also, which transponder should I have selected? My signal strength changes with transponder.
Thanks guys
