I know a lot of this has been covered in other threads but I hope someone will be willing to give me some specific advice.
MY current set up is one line from ground block( see picture ) to TV 1
And one line from ground block to TV 2 each feed a 722 dish dvr.
The analog output from both dvr go to a combine at TV 1 also a ota lead into the combiner It feed a splitter that feeds 3 TV and the two dvrs .
Will be moving to a hr34 and two hr24 one at each TV locations. House is on a crawl space that you must crawl.
Now for the part I need input on.
Option one
get a box of rg6 solid copper and run 4 leads in to the three tv and one for the power supply then have the installer mount the 16 swm outside put the ends on and install the new dish . This might be the best option but I would incur the cost of the cable plus the cost of paying someone to run it.
Option two is just let the installed show up and see what he can do will they crawl?
Can they use the two dish lines and only run one more?
I would prefer to leave my internal cable in place to deliver ota to all three TV
thanks
Option one
thanks
