Intelsat 5 Hor. &Ver polar.
$735.00
a_savvin
5
HI,
I installed my dish with viewsat fta receiver.
For some reason I can find/see only channels with Vertical polarization.
Check and make sure your receiver is properly set up for the type of LNB you have. You may not be sending the proper switching voltage to the LNB.
a_savvin said:
HI,
Is this a newer dish you bought? Just making sure you are not using an old Primestar dish (which most split the Polarity).
a_savvin if you are using a Primestar LNB that could be the reason why you are getting only vertical channels. The Primestar LNB's will also work using a switch.
HI,
Looks like i have to use switch. I just change head connector to another one and I was able to get H polar.
Thanks a lot
a_savvin said:
That can't be the lnbf you have, if you're on IA5 and you're getting any channels. If it is? I'm scratching my head!
Al
i think i have standard single LNBF 10750.
I already installed it, so i couldnt reach head to read label on back side of head.
Satellites I have scanned in - did I miss any?
What is component out
