lnb problems
Plyle
5
weslaco texas
I had an lnb fail on my old style ITB dish connected to a fortec star life time ultra. I put a geosat pro bullet lnb and couldn't get quality above 40. I borrowed an old lnb and got quality level of 75. I am receiving adventist channels on galaxy 19. Have to return borrowed lnb. What lnb do I need to get? Appreciate any help. Thanks
The GEOSATpro LNBF should work fine. Are the LNBFs Standard type with LO 10750 or Universal type with LO 9750/10600? Is the receiver set to the correct LNB type and LO? Make sure that the correct LNB type and LO frequency are selected to match the installed LNBF, otherwise the receiver will not tune the channels.
The GEOSATpro SL1 is the correct LNBF for your system.
I would suggest that maybe the distance from the dish to the GeoSat Bullet wasn't correct.
So, not focused.
I forget off hand how to set 'em relative to others, but that's what comes to mind if you had any troubles.
edit: read review on dual-output model, where this is discussed.
And I'm sure you adjusted the skew to maximize the signal quality... ;)
SO..Who Got an OpenBox for Christmas, or Nearly So??
Some Digitrans-7150 questions
