Low Signal on 99CA Only...
$885.00
TheTechGuru
1,862
226
Texas
101 is great, 99CB, 103CA, and 103CB all normal (upper 80's to mid 90's) but 99CA is upper 60's to mid 70's with TP 17 being 52 right now.
78 73 71 76 76 77 64 73
52 76 77 76 79 72 76 75
SWM uses a dedicated link channel for each receiver right? So it can't be a cabling issue as that would affect all of the satellites not just one right? It rained a lot today...
There's a common SWiM channel for guide info. centered at 974 MHz. And a common low data rate SWiM control channel cent. at 2.3 MHz for the receivers to communicate commands to the SWiM multiswitch.
My levels are all normal here on 99(ca).
Can you temporarily switch receiver locations to check for a possible cabling or LNB issue?
Sent from my LG-H932 using Tapatalk
I wouldn't worry about it if 99cb Is good and 99ca isn't
Um why?! There is a huge chunk of channels I can not watch reliably.
CNNHD 202
HLNHD 204
ESPNHD 206
ESNHD 207
ESPN2HD 209
MLBNHD 213
NBAHD 216
TNNSHD 217
GolfHD 218
FS1HD 219
NBCSHD 220
HGTVHD 229
foodHD 231
COOKHD 232
E!HD 236
BRVOHD 237
AUDHD 239
PARHD 241
USAHD 242
SyfyHD 244
TNTHD 245
TBSHD 247
FXHD 248
COMHD 249
LIFEHD 252
LMNHD 253
AMCHD 254
BBCAHD 264
A&EHD 265
FYIHD 266
HISTHD 269
DSCHD 278
TLCHD 280
VEL 281
APLHD 282
DISeHD 290
DXDHD 292
CNeHD 296
NIKeHD 299
NKJRHD 301
FRFMHD 311
MTVHD 331
MTV2HD 332
AUDHD 334
VH1HD 335
BTVHD 353
ACCUHD 361
TP 15 is at 0 and TP 17 is at 54 so I can not watch the following at all.
ESNHD 207
BBCAHD 264
FYIHD 266
NIKeHD 299
BTVHD 353
PARHD 241
VEL 281
DISeHD 290
DXDHD 292
Yes, those numbers are much too low.
If your 99cb signals arein the high 80s, looks like an LNB problem
Ok, checked the living room receiver (it was finally not in use) and all numbers are fine on it.
So am I looking at a receiver problem? Because with the way SWM works I don't think a wiring problem would affect just one sat and drastically affect just two transponders...
CNNHD 202
HLNHD 204
ESPNHD 206
ESNHD 207
ESPN2HD 209
MLBNHD 213
NBAHD 216
TNNSHD 217
GolfHD 218
FS1HD 219
NBCSHD 220
HGTVHD 229
foodHD 231
COOKHD 232
E!HD 236
BRVOHD 237
AUDHD 239
PARHD 241
USAHD 242
SyfyHD 244
TNTHD 245
TBSHD 247
FXHD 248
COMHD 249
LIFEHD 252
LMNHD 253
AMCHD 254
BBCAHD 264
A&EHD 265
FYIHD 266
HISTHD 269
DSCHD 278
TLCHD 280
VEL 281
APLHD 282
DISeHD 290
DXDHD 292
CNeHD 296
NIKeHD 299
NKJRHD 301
FRFMHD 311
MTVHD 331
MTV2HD 332
AUDHD 334
VH1HD 335
BTVHD 353
ACCUHD 361
ESNHD 207
BBCAHD 264
FYIHD 266
NIKeHD 299
BTVHD 353
PARHD 241
VEL 281
DISeHD 290
DXDHD 292
Because the signal is technically good.
Unless those channels are breaking up I wouldn't worry about it.
Yes, swap the receivers as a test.
I do not understand Claude's posts at all.
Well this morning I got up and it's working fine...but the numbers are still about 8 points lower than CB but now TP 15 and 17's numbers blend in with the rest of them.
So I'm thinking the LNBF is letting water in and it dried over night. It's supposed to rain again we'll see if it does it again...
It did it again even before any rain got here. I just moved here a week ago BTW and the dish and wiring was already here.
So for the first time since moving here I got up on the roof to take a look (can't see it from the ground). Found a SL3 with a 8-way splitter feeding only two lines. How dumb to use a 8-way to feed 2!
First I swapped the SL3 for my known good SL5 LNBF and problem did not go away.
So I swapped the DirecTV SWM 8-way splitter for my known good DirecTV SWM 2-way splitter and walla! Numbers on both receivers now match.
Reactions: Jimbo and raoul5788
Glad to hear it ...
I really thought is was a cable/splitter proplem, since if it was the LNBF it should affect all the receivers as its a SWiM integrated type.
I just needed to confirm it wasn't the receiver, which is why I asked for the swap location test.
It really makes no sense that an 8 way splitter would cause that, so I wouldn't assume that what you did actually fixed anything. Sometimes simply moving/tightening cables appears to fix things, but it may not be permanent.
Although an 8-way splitter is absolutely not optimum where a two way is enough, there had to be another issue. As slice1900 says, there might be a bad connector that just "fixed itself" temporarily
MLB NLCS in 4K
Dumb question probably
