I'm having brain failure tonight. If mounting second lnb on motorized dish, the switch goes after the motor, In the coax line going to lnb's? Don't I need a 22khz switch rather than diseqc switch?
Just to clarify for those looking to put a secondary LNBF next to the main LNBF for reception of 103W on a motorized dish:
Remember that, because the dish bounces the signal, the secondary LNBF is mounted opposite of the way the satellites are arranged in the sky. For example, if you want to hit a secondary satellite that is in an orbital position East of where the main LNBF is aimed, you would mount the secondary LNBF WEST of the main LNBF, and vice versa.
It is probably best to put the secondary LNBF to the WEST of the main LNBF. The reasoning behind this is that some LNBFs protrude downward where the coax is connected, and that protrusion would hit the main LNBF when skewed to the East for 103W if the secondary LNBF was mounted to the East of the main one. This is probably a moot point with "bullet" LNBFs and some other designs, as they do not have a protrusion and are more or less totally cylindrical.
If the secondary LNBF is mounted West of the main LNBF, you would want to either add a dummy satellite at 109W or change the coordinates of 103W to 109W. If you mount the secondary LNBF East of the main LNBF, it will be receiving 103W when the main LNBF is at 97W.
Hope this helps...
How much difference can it really make to turn the LNB by 26 degrees? The cosine of thirty degrees is 87% so we are talking about a loss of signal of only 11 or 12% without turning the LNB. Most of the Ku signals on that bird are pretty weak anyway.![]()
I know what I'm missing but increasingly, I don't care !Yes, the notion was explained to me quite a while back because I didn't detect the difference, either.
Well, the point being, if you didn't know WHAT you were missing, you wouldn't miss it.
RADAR
Small break through. I was finally able to receive COZY TV channel via the 103.0 W satellite. Unfortunately my signal quality is low and it fluctuates between 40 - 55 on my micro HD. The result is video pixellation issues. My 2nd lnb is currently mounted to the left of my primary lnb - when facing the dish. I was wondering if mounting the 103.0 W lnb to the right of my primary lnb would be worth a try. I need to get my signal quality up to watch this channel. I believe I have tweaked the skew of the lnb to optimize my signal gain. Also, if anyone in the Boston area is receiving COZY TV via 103.0W could you please let me know what your signal levels are and what size dish you have? Any suggestions would be appreciated. Thanks
