Okay, I finally got my satellite mounted, and am trying to pick up 123W. I am pretty sure I have it aligned correctly.
Here is my info:
The post the dish is mounted on is not perfectly plumb, but it is so close to being there, I don't think it would keep me from picking something up.
Viewsat Ultra Lite Receiver - coax runs from the LNB to SAT IN jack on receiver and then RCA out to TV
Hughesnet Dish (26x39) using the origninal LNB and took off the transmitter.
I used this website to find all the angles: Satellite finder, how to point dish with magnetic north, azimuth and elevation program calculator.
My lat is 36.11 N
and long is 97.08 W
I made the dish elevation 40 (the bracket on back has an adjustable slot for elevation changes)
I moved the dish azimuth to approx. 217 degrees according to the sat. finder calc. (i used a compass and the 217 is relative to magnetic north)
The hughesnet dish requires you to move the entire dish to set the skew. There are nice angle marking on the back where you rotate it so I moved it clockwise to as close to 30.9 as I thought it could be.
When viewing the antenna setup from the viewsat I have these settings for the satellite:
Galaxy 18 (123W)
LNB Power on
LNB Type standard
LNB freq 10750
22KHz off
TP freq. 11720
DiseqC 1.0 none
Motor off
"S" signal strength is 67
"Q" signal strength is 0
when I autoscan for channels nothign is found.
What are the "S" and "Q" signals and why does my "Q" signal have a 0 strength?
What is TP freq.?
What do I need to do to find the channels from sat 123W?
A pic of the dish and LNB I'm using is attached. The pic is old, so the dish isn't shown mounted, but it is now
Here is my info:
My lat is 36.11 N
and long is 97.08 W
Galaxy 18 (123W)
LNB Power on
LNB Type standard
LNB freq 10750
22KHz off
TP freq. 11720
DiseqC 1.0 none
Motor off
What is TP freq.?
