Hi All-
I'm new to the world of satellite TV, and looking forward to enjoying a new set of tech. gadgets and TV channels
However, right now I'm really struggling. My first mission is to get channel CCTV4 on G3C, and after spending a number of hours, I have yet to see anything but a blank screen on the TV. Here's what I have:
Equipment:
Vistar/Viacast 2000 purchased off of eBay
.9dB Ku band LNBF left over from an older analog setup
1m dish
$10 cheapie satellite finder meter from eBay
Seattle, WA
I show G3C at:
Elevation 29.3
Azimuth 145
LNBF -22.7
Magnetic deviation approx 18
Questions:
Thanks.
Equipment:
1m dish
Seattle, WA
I show G3C at:
Elevation 29.3
Azimuth 145
LNBF -22.7
Questions:
- I should subtract the deviation from the azimuth to get the value on the compass I should point at(e.g. 127 on the compass), correct ?
- How accurate do I need to be? I have a lousy tiny compass, so I can only get to within about +/- 5 degrees, is this a problem? I am also "eyeballing" the LNBF tilt and Elevation. Is this uncool? what's a good cheap tool to calculate these things accurately?
- Could my old .9 dB Ku band LNBF be my problem? Is there a difference between analog and digital or something? Is 0.9dB too lousy to get a digital signal?
- In the vistar setup menu, there is an entry for "LNB power" and one for "Symbol rate". How do I figure out what these values are? Using the lyngsat database I can get frequency, but I don't see any LNB power or sybol rate information. From another post on this forum I gather LNB power is also known as "polarity".
- Are the cheap satellite finders worth using/accurate? I can't really get much out of the meter (I was hoping it would really spike up in some areas, but no luck), but I don't really have a clue as to what I'm doing.
- I see a bunch of people look for a True South satellite. Do I need to do this if I'm not using a motor? The first goal is to just get a single channel on a single satellite working...
Thanks.
