newbie needs help with installation
timichel
4
i am new to FTA. I have 2 coolsat 5000, Stab HH90 motor, 30'' antenna, Invacom QPH-031 Quad Polar LNB.
1) I need to know how to connect the Invacom Qph-031 Quad LNB to the motor since the motor only has one input for lnb. I also need to know how to connect both receivers since the motor only has one input for receivers
2)What is my true south satellite, my longitude, Latitude and dish elevation
I live in Miramar, FL 33027
3) On the menu page for the Coolsat 5000 they ask for
LNB Type ? (keep in mind that I have the Invacom QPH-031)
LNB Frequency ?
22KHZ ?
4) I am getting in red Level 71, quality 7
Your help would be greatly appreciated
Just use one output marked L for now until you are all set up, remove any switches.......
1/ I use a 2 way DiSEqC switch, you could also use a 4 way DirecTV switch for 2 receivers.
2/ see below
3/ The linear side of your LNBF is a STANDARD, so the L.O. should be 10750
4/ Level means NOTHING you are only looking for quality
I would use AMC-5 as a (near) true south satellite
Good idea to remove the motor and find and store this satellite before adding the motor........
Code:
                     Hollywood, FL 33027
         Latitude 25° 59.844'N Longitude 80° 19.488'W
                       Sat Name Sat Lng Az(t) Az(m)   El  Skew
           Thor 2/3 Intelsat 10    1.0W  94.7 100.6  0.9 -63.6
                       Amos 1/2    4.0W  96.1 101.9  3.6 -63.3
                Atlantic Bird 3    5.0W  96.5 102.4  4.5 -63.2
                Nilesat 101/102    7.0W  97.5 103.3  6.3 -63.0
     Telecom 2D/Atlantic Bird 2    8.0W  98.0 103.8  7.2 -62.9
                     Express A3   11.0W  99.4 105.2  9.9 -62.5
                     Telstar 12   15.0W 101.4 107.2 13.6 -61.8
                   Intelsat 901   18.0W 102.9 108.8 16.3 -61.2
                          NSS 7   22.0W 105.1 111.0 20.0 -60.2
                   Intelsat 905   24.5W 106.6 112.4 22.3 -59.5
                   Intelsat 907   27.5W 108.4 114.2 25.0 -58.5
                  Hispasat 1C/D   30.0W 110.0 115.8 27.3 -57.6
                   Intelsat 801   31.5W 111.0 116.8 28.7 -57.1
                   Intelsat 903   34.5W 113.1 118.9 31.4 -55.8
                    AMC 12/T 11   37.5W 115.3 121.1 34.0 -54.3
                        NSS 806   40.5W 117.7 123.6 36.7 -52.7
                      Pas 3R/6B   43.0W 119.9 125.7 38.9 -51.2
                         Pas 1R   45.0W 121.7 127.6 40.6 -49.9
                   Intelsat 705   50.0W 126.8 132.7 44.7 -46.0
                   Intelsat 707   53.0W 130.3 136.1 47.1 -43.3
                   Intelsat 805   55.5W 133.5 139.3 49.0 -40.7
                          Pas 9   58.0W 136.9 142.7 50.8 -37.9
                       Amazonas   61.0W 141.3 147.2 52.8 -34.2
                     EchoStar 3   61.5W 142.1 148.0 53.1 -33.5
                      Rainbow 1   61.5W 142.1 148.0 53.1 -33.5
               Estrela do Sul 1   63.0W 144.6 150.4 54.0 -31.4
                   Brasilsat B2   65.0W 148.0 153.8 55.1 -28.5
                   Brasilsat B1   70.0W 157.4 163.3 57.5 -20.2
                       Nahuel 1   71.8W 161.1 167.0 58.2 -16.9
                      DirecTV 1   72.5W 162.6 168.4 58.4 -15.6
                          AMC 6   72.0W 161.5 167.4 58.2 -16.5
                          SBS 6   74.0W 165.8 171.6 58.8 -12.7
                     Echostar 4   77.0W 172.5 178.3 59.4  -6.8
                          AMC 5   79.0W 177.0 182.8 59.6  -2.7
                        Nimiq 2   82.0W 183.8 189.7 59.6   3.4
                          AMC-9   83.0W 186.1 191.9 59.5   5.5
                   Brasilsat B3   84.0W 188.3 194.2 59.3   7.5
                          AMC 2   85.0W 190.6 196.4 59.2   9.5
                          AMC 3   87.0W 194.9 200.8 58.7  13.4
                           IA-8   89.0W 199.2 205.0 58.1  17.2
                      Galaxy 11   91.0W 203.3 209.1 57.4  20.8
                      Nimiq 1/3   91.0W 203.3 209.1 57.4  20.8
                   Brasilsat B4   92.0W 205.2 211.1 56.9  22.5
                      Telstar 6   93.0W 207.2 213.0 56.5  24.2
                      Galaxy 3C   95.0W 210.9 216.7 55.5  27.5
                      Telstar 5   97.0W 214.3 220.2 54.4  30.5
                      Galaxy 4R   99.0W 217.6 223.5 53.2  33.3
                     Spaceway 2   99.2W 218.0 223.8 53.0  33.6
                DirecTV 1R/4S/8  101.0W 220.7 226.6 51.9  35.9
                          AMC 4  101.0W 220.7 226.6 51.9  35.9
                     Spaceway 1  102.0W 222.2 228.0 51.2  37.1
                          AMC 1  103.0W 223.6 229.5 50.5  38.3
                         AMC 15  105.0W 226.3 232.2 49.1  40.6
                      Anik F1/R  107.3W 229.3 235.1 47.3  42.9
                      DirecTV 5  109.5W 231.9 237.7 45.6  45.0
                     EchoStar 6  110.0W 232.4 238.3 45.2  45.4
                     EchoStar 8  110.0W 232.4 238.3 45.2  45.4
                        Anik F2  111.1W 233.6 239.5 44.3  46.4
                  Solidaridad 2  113.0W 235.7 241.5 42.8  47.9
                       SatMex 5  116.8W 239.3 245.2 39.6  50.6
                     DirecTV 7s  119.0W 241.3 247.1 37.7  52.0
                     EchoStar 7  119.0W 241.3 247.1 37.7  52.0
          EchoStar 9/Telstar 13  121.0W 243.0 248.8 35.9  53.2
                     Galaxy 10R  123.0W 244.6 250.4 34.2  54.3
                      Galaxy 14  125.0W 246.1 251.9 32.4  55.3
                  Galaxy 13/H 1  127.0W 247.5 253.4 30.6  56.2
 Intelsat Americas 7/Echostar 5  129.0W 248.9 254.8 28.8  57.0
                         AMC 11  131.0W 250.2 256.1 27.0  57.8
                   Galaxy 1R/15  133.0W 251.5 257.4 25.2  58.5
                         AMC 10  135.0W 252.7 258.6 23.3  59.1
                          AMC 7  137.0W 253.9 259.8 21.5  59.7
                          AMC 8  139.0W 255.1 260.9 19.7  60.3
                     EchoStar 1  148.0W 259.8 265.6 11.4  62.2
                     EchoStar 2  148.0W 259.8 265.6 11.4  62.2
       Satellite Finder is (c) Copyright 2004, P. Lutus
Only one receiver will be able to control your motor. When you get everything set up and its time to add the switch, it goes between the LNB and the motor. The motor should be connected directly to the receiver that will control it.
Receiver -> Motor -> Switch (DiSEqC or 22k multiswitch) -> LNBF
Spin you own dish?
Problem with Captiveworks CW-600S
