NO Analog channels ?
I moved your post to a newer thread
The 24/7 stuff on C-Band I posted above
There is no 24/7 analog on KU anymore. Those "test cards" on KU are digital
There may be feeds on KU in analog but they are few and far between. There isnt a spot where to find them. They vary
well if I remember right almost all of the 24/7 analog feeds are also in digital
91W
Classic Arts 18V
digital feed on same transponder
99W
Shepherds Chapel 16V
no digital feed. Lots of tv stations pick up an hour or two of the feed for programming
125W
ShopNBC 5H
digital feed same sat
131W
C-Span 7V
digital feed too (scrambled) but I think part of their agreement is to stay in analog
Weather 13V (scrambled)
other feeds in digital..scrambled
133W
EWTN 11H
about 20 feeds on 91W in digital. HD feed on this sat too
Inspiration 17H
I dont think there is a digital feed of this one
135W
QVC 9V
HSN 10H
digital feeds out there including HD
Why are they still analog? Some cable co's might still be getting them this way...also agreements between channels and satellite uplink companies go for years so they may be running the contract out
Is the information in lyngsat.com up-to-date ? There are few satellites that are still broadcasting analog transmissions. :)
72,0W: AMC 6
- C-Band tp16 (feeds) (NTSC)
- C-Band tp20 (feeds) (NTSC)
- C-Band tp21 (feeds) (NTSC)
- C-Band tp22 (feeds) (NTSC)
- C-Band tp23 (feeds) (NTSC)
- C-Band tp24 (feeds) (NTSC)
- Ku-Band tp22 (feeds) (NTSC)
79,0W: AMC 2/5
- Ku-Band tp15 (feeds) (NTSC)
83,0W: AMC 9
- Ku-Band tp4 (feeds) (NTSC)
- Ku-Band tp8 (feeds) (NTSC)
- Ku-Band tp14 (feeds) (NTSC)
- Ku-Band tp20 (feeds) (NTSC)
87,0W: AMC 3
- C-Band tp11 (feeds) (NTSC)
- Ku-Band tp3 (CNN Feeds) (NTSC)
89,0W: Galaxy 28
- C-Band tp109 (feeds) (NTSC)
- C-Band tp112 (feeds) (NTSC)
- C-Band tp114 (feeds) (NTSC)
- C-Band tp119 (feeds) (NTSC)
- C-Band tp120 (feeds) (NTSC)
91,0W: Galaxy 17
- C-Band Classic Arts Showcase (NTSC)
95,0W: Galaxy 3C
- C-Band tp4 (feeds) (NTSC)
- C-Band tp6 (feeds) (NTSC)
- C-Band tp9 (feeds) (NTSC)
97,0W: Galaxy 19
- C-Band tp15 (feeds) (NTSC)
99,0W: Galaxy 16
- C-Band Shepherd's Chapel (NTSC)
- C-Band tp17 (Disney/ABC feeds) (NTSC)
- C-Band tp18 (Fox feeds) (NTSC)
103,0W: AMC 1
- C-Band tp1 (feeds) (NTSC)
- C-Band tp9 (HUD feeds) (NTSC)
- C-Band tp21 (Univisión feeds) (NTSC)
- C-Band tp23 Rai Italia (Mon-Fri 18-20 & Sat 19-20 & Sun 08-14 ET) (NTSC)
105,0W: AMC 15
- Ku-Band tp12 [EchoStar info card] (NTSC)
107,3W: Anik F1R
- C-Band tp12A (feeds) (NTSC)
111,1W: Anik F2
- C-Band tp1B VSEN Henrico (08.45-11.30 ET) (NTSC)
- C-Band tp3B VSEN Varina (08.45-12.30 ET) (NTSC)
- C-Band tp5B (feeds) (NTSC)
- C-Band tp6B (feeds) (NTSC)
- C-Band tp7B VSEN Wise (08.30-13.17 ET) (NTSC)
- C-Band tp8B (feeds) (NTSC)
- C-Band tp9B (feeds) (NTSC)
116,8W: SatMex 5
- Ku-Band tp12 (feeds) (NTSC)
123,0W: Galaxy 18
- C-Band tp 2 (feeds) (NTSC)
125,0W: Galaxy 14
- C-Band ShopNBC (NTSC)
127,0W: Horisons 1
- C-Band tp14 (feeds) (NTSC)
131,0W: AMC 11
- C-Band C-SPAN (NTSC)
- C-Band The Weather Channel US (NTSC; Scrambled in VC2)
133,0W: Galaxy 12
- C-Band EWTN US (NTSC)
- C-Band INSP (NTSC)
135,0W: AMC 10
- C-Band QVC US (NTSC)
- C-Band HSN (NTSC)
Where can I find an up-to-date version of this list?
But I was going to ask about the feeds entries.
Which of them are still valid and which of them should be removed from the publicized lists?
I havent seen an analog "feed" in a long time.....so pretty much all of those are no longer valid.
Much easier to use digital and saves money as you're not hogging a whole transponder
honestly I'd have them all removed. Analog feeds are really no longer used unless they are a sports feed and those are a rare sight. The original date of the thread has been over a year ago and back then there were only a few analog wildfeeds at the time. Those have long been gone last summer and they are now digital because they are broadcast in HD (cant do analog HD) ;)
I bet if they could, the quality would absolutely blow away ANYTHING digital!
not necessarily....
analog takes up a whole transponder
Digital HD from the "big boys" takes up a whole transponder (30000 or 29270 s/r)
it all depends on how much bandwidth they want to use :)
