Go into "MENU",
OK "Instalation",
Enter "Password" should be 0-0-0-0,
Arrow (up/down) to "Edit TP/Satellite",
OK "Edit TP/Satellite",
OK the particular Satellite,
Arrow (up/down) to "Edit TP",
OK "Edit TP",
Arrow (up/down) to desired TP,
OK desired TP,
Choose between "EDIT" or "Delete" using right/left arrows, "Delete" according to your question,
OK "Delete", or "Edit" if you're changing TP, SR, or PID's,
Select OK again if you want to "Delete", or select "EXIT" if you've changed your mind...
Then, "Exit" out, or "Delete" or "EDIT" other TP's if necessary.
Al
