PLL LNB
Wiring up multiple UNIVERSAL LNBFs to multiple receivers is a bit of a challenge.
Especially if it won't do you any good.
STANDARD LNBFs provide more wiring flexibility.
Both are addressed in the Switches Simplified FAQ.
For one receiver, it really doesn't matter.
?I'm too far west to consider Universal.
I have done a BIT of side by side testing of RG-59 vs RG-6. SO --- the size of the center conductor WAS the major drawback! The RG-59 will be loose enough at the connector to cause a problem. On the sweep, it shows up as rectification! Your testing may be different. (KTBW - Federal Way TBN studio, 1986-88, Microwave NW.)
180w didnt work for me here in L.A using a 1.2m dish a few months ago.. my HH120 motor was stretched to the max and looked like it was gonna tilt over my wooded deck.
This is one of those situations where you probably need a fixed antenna, and in some circumstances, tip it upside down with the LNBF on top half of antenna. But EIRP maps show a solid signal across SoCal and neighboring region if you have LOS.
Why does Galaxy 19 have so many customers?
Semi-old-timer upgrading system-how does this setup sound?
