Question on motor dish
vargf
47
Today I setup a Stab Motor (HH90) with a 40" anttena on latitude I put my latitude 34.46 Latude north now when I go to set up my Fortec Ultra Life and I put USALS for the motor I turn the 22KHz on,now the dish move but just a little and almost is in the center 180 degres Azimuth. My LNB is a Imvacom 0.3 DB Circular /Linear Quad QPH-031. I put in the center 0 tilt. My latitude North is 34.46 and my 117.19 West longitude.My dish Elevation is 39.4 but the question is corret
my set up because the 180 degre Azimuth but I don't the The True south to substrac or add , cable RG6 Can any body advice the true set up because I'm lost.
:confused:
The linear side of the QPH-031 is a Standard so the L.O. should be 10750 with the 22KHz off.
I would remove any switches also for now.
Try this
Your lat/log is like L. A. or vicinities areas, Magnetic Deviation around 15
True South - magnetic deviation
In this case: 180 - 15 = 165
Dish Elev. : 39.4
Select the nearest sat from your longitude and adjust antenna elevation and motor east/west
For you I recommed SATMEX5 116.8: Elevation 49.1, Az. 179.3
Good luck
Cabling Questions
Now what!
