receiving c band channels
krisman
SatelliteGuys Guru
127
tn
i have my sv 360 and fortec 36" working now, i can get most all of the ku channels but there are a couple on c band that i would like to have. they assured me that the dish would pick up c and ku band. i really need some help though. how do i go about picking up c band and if the use a different frequency or not? i think sonicview is made for kuband only. so would a coolsat 6000 or a traxis 3500 pick up c band?
36"fortec star, Invacom Quad Polar LNB, and sg 2100
Your receiver can do it, no problem, but you need a bigger Dish, usually 6 foot or larger, and a C Band LNB.
Who assured you that the "Dish" would do C Band?
some agent i talked to online said that. a motor would not pull a 6 foot dish though would it? and how would i go about looking for a cband dish? sounds like a lot of work changing the dish and all.
If you look around you should find a 10' free locally with motor and all.
C-not only c-band to some
They prob were confusing c-as in circular ports on that lnbf with c-band, two diff things. As stated, you need a bigger dish and a c-band lnb or lnbf.
well let me ask ths. will a c band dish pick up ku? and my sg 2100 motor wouldnt pull this dish at all?
as long as the mesh is small (you cant slide a pencil through it) then you should be OK
no way the SG2100 moves the 6 footer. It dies on a 120cm dish ;)
AMC 4 101W
Red Notice on RTN Channels
