Recommendations for DiSEqC 2.0 switches with at least 4 ports?
ancient
443
231
USA
I recently had a 4 port DiSEqC 2.0 switch die on me and probably should consider getting another, since that was my last spare. It's been several years since I purchased one and back then many of the DiSEqC switches were rather unreliable, and easily zapped by lightning or static, or by forgetting to cut the power before connecting or disconnecting anything. Has the technology improved at all? Are any of the DiSEqC switches available today more robust, or is it just more of the same old thing?
Cost is somewhat of a factor. I'm not going to spend a huge amount on a switch because no matter how good it is, a nearby lightning strike will probably zap it, so I never plan on anything like this lasting forever. I could just buy the cheapest switch that comes with some kind of guarantee against being DOA, and buy another each time it fails, but if spending a little more will get me something that's known to be of better quality, that would be my preference.
I´m currently using a DMS International DS 7241 Diseq switch with 4 ports, it has been in use for about 3 years now, working fine, it was nothing expensive, and I have it practically without any protection from the weather.
You get what you pay for. All DiSEqC switches are somewhat sensitive to ESD and voltage spikes. Better built switches are more tolerant. 99 cent fleabay cheapies, not so much.
It is usually the cheapies that have switching issues over distance or quirks with different STB's.
And by what you pay I don't mean you need to spend $30 on a 4x1. There are good ones out there that are reasonably priced (<$10) but good quality. Personally I'd rather spend $10 once and forget where I installed the switch than get 5pc $2 units and be outside replacing all the time.
the amiko 8x1 don't cost too much, its reliable, and leaves plenty of room for expansion. got one myself and recommend it :)
Agree with primestar31. The heavy duty Chieta is excellent. Even ran my Stab90 motor thru it with no problem.
You should be able to find them for under $10.
This one claims to have the same specs but costs much less. I notice it doesn't have the CNX logo. Any ideas if it's a quality switch or a cheap knock off?
It's the same switch. I used to buy them all the time for under $10. Not sure why the other guys suddenly jacked their prices so high.
Tried fta on small dish
project: closest thing to heaven is a hardware store
