RG 11 Connector Install
It looks like a compression-type connector, but I'm not sure what kind of compression tool it will require to secure it in place.
I found out for sure it is a PCT compression type, if you look closely at the fitting you can see 2 rings at the base that actually kinda collapse when you compress it, and make a watertight seal, needing no extra sleeves. The PCT tool was like 60 bucks, pretty average, and it does RG6 also so I got some RG6 connectors for another project. Thanks for all your help!
