PSB said:I am getting 40% signal quality, much the same as The Peoples Network and most of the others on AMC-4, but thats on the ST3618 and a Universal LNB, I am sure it would be around 70% with my low noise standard Ku LNB, on my BEC 2000 the quality is at 60% with the same Universal LNB. I am getting a bit fed up with this low quality Universal LNB I think I will change to the standard, all I get extra with the Universal is Cubavision, but it brings all my other signals way down!
red hazard said:I don't think it's correct to infer that the Universal LNBs are inferior to standard LNBs. I have two Big Sat International Universal LNBs on two mediocre HotDish75 antennas and get the following readings on AMC-4:
TP1 86% SS/64% SQ
TP2 85% SS/48% SQ
TP4 85% SS/89% SQ (that's not a typo)
TP5 85% SS/74% SQ
TP7 85% SS/61% SQ
All numbers are from a PANSAT 2000V going through about 60ft of Belden 1694A RG6, a 2X1 DiSEqC switch, and a TrippLite ISOBAR 5 DBS Surge Suppressor. The previous FORTEC Universal LNBFs had SQ readings about 10% less. Got the Big Sats on Ebay for $14.50 each but the S&H from Austria ran about $20. The NF is only .3db which accounts for the improvement in SQ.
Virgil Gomes said:The people who are getting RPTi on AMC4, what brand name and model number reciever are you using?
I finally got RPTi on my Samsung DSR 3800, but found that I had to use freq. 12170 instead of 12169 to get it. Has any one else run into this problem?
