Sat 103 (a) Transponders
hikersc
11
I had a Slimline (5 LNB) Dish installed about two weeks ago as an upgrade to HD. I decided to write down all of my transponder signal strengths for future reference if I had a problem. Although I have not noticed any problems, I ran the same check today and noticed that 1 - 6 transponders on Sat 103 (a) were now reading 0 but were 97 73 98 0 98 78 when I first checked two weeks ago. All other 10 transponders on 103 (a) are the same and all other Sats (101, 110, 119, 99 (b), 103 (b)) are the same.
Any idea why transponders would come and go? The first check was on a Saturday and the last check was today (Monday). I would have thought any alignment shift would effect all transponders on a particular Sat.
The 103a satellite is used for spot beams to provide locals. D* from time to time moves channels to different transponders, and as a result, relocate where some transponders are aiming at, resulting in fluctuating signal levels. As long as you aren't missing any channels, I wouldn't worry about it.
Local HD Channels Pixelating
3 Separate Dishes, Which Switch
