Satellite Puzzle
Plywodstatebum
829
16
A Secluded Beach In, Fl.
for the last 4 days my 2 bedroom HR 24 DVRs have lost there signals after watching TV for 45 min. I get 775 error saying the Sat isn't communicating with the 2 receivers. Yet the Genie in the living room is working fine.
So Any Ideas??
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
775 is usually something wrong with the power inserter connections with the lnb. Have you checked all of the connections? Check where the HR24s connect to the splitter or swm8/16.
Plywodstatebum
829
16
I went in the attic (150 degrees) lol And checked all the wires and nothing so I beat on the splitter and it started working.... yahoooo I can watch skin-a-max and football.. The repair guy is coming the 9th ,, I'll tell him to replace all the crap in the attic..
Reactions: raoul5788
Drucifer
920
111
NY Hudson Valley
So Any Ideas??
Got that a couple months ago. DirecTV replaced the SWiM16.
twizt3dsist3r
2,962
212
Pennsylvania, United States
775 is a generic swm related error. All it means is that particular box is having problems communicating with the dish. It could be anything from a defective splitter to bad connectors or possibly faulty wiring. It could mean a bad power inserter under certain circumstances. . But since you said one tv is working I highly doubt it has anything to do with the pi or lnb.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
Exactly why I suggested he check his connections first.
texasbrit
Cutting Edge
Apr 12, 2006
3,654
365
You have nine tuners and an SWM dish can only support eight....do you have an SWM16 multiswitch??
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
I should read the posts better! You are right texasbrit he has 9 tuners, but would that give him a 775 error?
texasbrit
Cutting Edge
Apr 12, 2006
3,654
365
Hence my comment....if he does have an SWM16, the next question is are the two HR24s on the same "side", and what happens if he moves one of them to the same side as the HR44..
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
But would too many tuners in a swm setup give a 775 error?
texasbrit
Cutting Edge
Apr 12, 2006
3,654
365
I would have thought not, I believe it should be a 776, but I'm not certain about that....
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
Hmm, so he could have two issues, too many tuners possibly, and a bad connection somewhere.
Plywodstatebum, do you know if you have a swm lnb or a swm switch, and if a switch, which model?
glen4cindy
641
38
St. Louis MO, area
I've had the same issue from time to time. I'm not certain the exact setup I have, but, I believe I have a SWM-16 switch. I have 4 coax lines coming out of my dish into this switch, then, although all of the lines are not in use any longer, there are what look like 4 way splitters coming from wires coming out of the SWM switch. These wires go to an HR-23, HR-24, & and HR-34 which gives me 9 tuners as well.
Sometimes, after a "power glitch" or rain issue, I'll get a 775 error. In my case, a "reboot" of the power inserter by giving it a power cycle has fixed the 775 error.
My SWM Switch and Power Inserter are in the drop ceiling of my basement and not in the attic.
Is the extreme heat of this environment a problem for these devices?
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
They are designed for high heat, so that's probably not a factor.
