Thanks for all the input. But the Pansat too has issues.
- It freezes alot especially on S2 feeds.
- Doesn't send AC3 Audio through HDMI
- PVR will not play back HD recorded content. Gets stuck.
- Very Hot even when off.
- Soft limits on USALS cannot be removed.
- Front display difficult to tell when receiver is ON or OFF.
I have had my 9200 for about two years. The S-2 board is the "plus" model. Depending on the serial number, some of the early ones needed to have a transistor re-oriented. Something to do with the PVR working properly. The fix for the early models is posted at the Panerex site.
I have not noticed any more freezing on S-2 signals than on the regular old S signals. However that said, it does have it's moments, but all receivers seem to at certian times it seems from what I have read. I have mine hooked up with the HDMI since day one. I have AC3 audio with no problem. So that does work, maybe it is your setup? Maybe it's your TV? And if it is the receiver, check the HDMI connection inside the receiver. There were some reports of the connection being bad and lifting up on the cable at the receiver gave audio. I however have not had that problem. On the PVR function, I have recorded several shows in HD and even transferred some to dvd in order to clear out drive space with not much trouble. I have had to re-boot the box on a few occasions, but not enough to really complain. On the heat issue, I myself do not run a fan. The box is well vented and is no warmer than the other stuff,4DTV, Stereo, and Tv itself. Some claim that a fan helps the freezing. I tried it for fun and saw no difference, except a cooler receiver but not in performance, after a week or so. So I ditched the noisy fan I had blowing on it. I use it with my 10 footer so I can't address the USALS issues. Finally, looking at the receiver when it is off, the colon flashes. If there is no colon showing, it's on. Have a great day!
