Signal Help
glenhoward68
26
I cant find 101, I have found 110 & 119, also have found 91 on bell expressvu (cdn) have marked all three
would the elevation be different between the 3 101,110,119
I am using a signal finder & nothing
Using setup under your menu, by your zip code you should get at azmith and a elevation. Those numbers are you 101 if your running a single or dual lnb. I believe you will need to be more accurate in what type of dish and lnb setup you have.
-Dave
"Release NFL Sunday Ticket to cable operator's then we'll talk".
D10 IR/RF remoting
