Starband dish, LOS issue to 129
kau
St. Louis metro
Because of surrounding trees, there is not a position on my roof or anywhere near my house which has LOS to both 110/119 and 129. If another dish is mounted where LOS isn't an issue with 129, could it be used with a switch and my Starband dish which is not used for internet? I currently receive a few HD channels on a 211k from 110. If this is possible, which components would work and about how much will they cost?
A guide I found
http://www.satellitetv.com/downloads/dishmanuals/SHOW_949_dishpro_install.pdf
shows a Dish 300 with a Dish 500 and a DP34. The Dish 500 may be similar to the Starband dish because it is either detected as or is configured to be a 500 in the 211k.
Thanks for your help.
Ben
Pictures of the Starband Dish and Dish components on the back are attached.
Yes you could add a second dish pointing at the 129* to that set up. To do it you would need to swap out the LNBs on the Starband dish to Dish Pro LNBs (If the aren't already). Then using a third Dish Pro LNB on your "wing" dish, and a Dish Pro 34 switch. You will need to run a cable from each LNB to the port on the switch, and then the output of the switch will each run one tuner in a Dish receiver (IE single tuner one line. Dual tuner two lines). If your 129* LOS location can get all three birds it would be much simpler to just get a 1000.2 dish, and be done with it.
Unusual input to 1000.4 dish
Speed TV HD
