Streaming to LAN
Cham
VE4GLS
2,584
1,165
Boonies
Just wondering how to set up the azbox to stream audio & video out to one of my LAN computers. I tried the streaming option in the menu when the receiver is active, put in the local computer IP, set up local computer to stream From azbox IP port 9000. No joy.
Using VLC Media Player on a P4 Windoze XP box.
I might be mixing up streaming "to" and streaming "from" somehow but going through the setup menu I find the same options in the azbox. Just curious how this works.
-C.
-C.
It could be a firewall issue on the PC. If you have another PC on your network that has nmap, you can scan the target PC to see if the port is open. That's the only thing I can suggest since I haven't tried streaming yet.
Port 9000 is available on the pc but I don't get a response from the azbox... but then I am not sure if it is sending from that port or not. Will try to figure that out. I might try using a different port but I expect that particular port (9000) is associated with streaming A/V content with other software as well as VLC. FTP, web, and telnet ports are open for sure.
AzBox ver # is 5020 so maybe it's not working... Not too many threads about streaming from the AzBox.
-C.
SAT LIST CORRUPTION AND OTHER QUIRKY BEHAVIORS SOLVED
Just installed! internal 1 TB drive into the Ultra!Need alittle help
