what exactly are you going to use for a pre-amp and joiner?Everything i need with the new uhf antenna, plus the joiner and pre amp will run me about 115 dollars.
This is the joiner I was talking about
http://www.solidsignal.com/pview.as...-Separator/Combiner-for-Antenna-(UVSJ)&q=uvsj
I see the antenna you have is a VHF Low/Hi/UHF one.
As for the pre-amp there is a RCA model that has separate VHF & UHF inputs (there is a switch to select separate antennas or a combo unit)
I got mine at Menards here in MN but I see solid signal carries them too
http://www.solidsignal.com/pview.as...ATVPRAMP1R)&c=Pre-Amplifiers&sku=044476071669
How far are you from the BR stations? I dont think I've seen your tv fool report.The HDB8X says the radius is 60 plus miles uhf. So by the time the baton rouge new channels launch i should have this up.
, yeah leave that alone but like you said turn the vhf boom west to kplc then ill be set up when grit launches in January
